The VATS Gremlin
I’m hoping someone might be able to give me a little help.
I have a 95 LT1 Auto. I lost / misplaced my keys which started my problems with VATS. I spoke with a GM Parts Manager (Nytro) on another Vette related site who told me a local dealership should be able to provide me with the key codes, door codes, and correct VATS code so I could get a new set of keys made. The dealerships in my immediate vicinity had no idea what he was talking about and in the end, Nytro finally provided me with the codes.
I managed to find a dealership further away from home that knew what Nytro was talking about. I went to their facility with registration, ID etc. in hand to get a new key cut. The dealership looked up my VIN # and was able to verify the key and door codes but was not able to verify the VATS code (11) I obtained from Nytro. I took a chance and asked them to cut the key using a blank that matched code 11. The new key does turn in the ignition but it will not start the car.
I’ve pulled the DTC codes and the code that comes up is “Invalid Key”. I’ve read the resistance of the key alone and I get the same value when I check the resistance through the wires coming from the key cylinder. I unplugged the wire coming from the key cylinder and connected a potentiometer to the wires leading to the CCM and tried all 15 possible values, waiting 10 minutes in between each attempt, but was unable to start the car.
Thinking I could have possibly done something wrong, I called a locksmith who used a VATS Interegator to inject each of the 15 codes and he was not able to get it to start either. During this process, what I finally noticed is that when the ignition key is turned to the on position, the Security light comes on and stays on instead of going off after a few seconds.
Unlocking the door with the door key causes the Security light to flash as normal. Using the door lock switch causes the Security light to come on normally until the door is closed and then it will go out. Opening the door with the system armed causes the alarm to activate and the horn blows. The key can then be used to turn it off. All normal functions.
Prior to misplacing my keys, I never had any issues or problems with the VATS system or starting (46K mi). The one difference between the past and now is that the FOB was on the key ring with the keys and I do not currently have one. When I did have the FOB, it armed and disarmed the system as expected. According to everything I’ve read, the absence of the FOB should not matter when it comes to determining the proper code.
Does anyone have any idea what could be causing the Security light to remain on or what else I could check?
Thanks,
Cliff
