Is my opti going out?
Old Jul 14, 2006 | 10:51 PM
90 Convertible's Avatar
90 Convertible
Default Is my opti going out?
I have had this car for a month and it has been running great. Today on the way to work the car stumbled on the highway like it was running out of gas for a couple of seconds then ran fine for a about half a mile then did it again then ran fine the rest of the way to work. On the way home I felt it again, so I stayed on the access road and sure enough about the 4th time it did it the car died. Car wouldn't start for about 10 minutes. When it finally started, it ran fine all the way home.
My buddy is coming over tommorrow with a scanner so we can pull any codes. Any codes in particular should I be looking for. It's a 1996 LT4.
thanks
Old Jul 14, 2006 | 10:58 PM
STL94LT1's Avatar
STL94LT1
Might also be your ignition control module (ICM).
Old Jul 15, 2006 | 01:45 AM
RRT vette's Avatar
RRT vette
could be anything ignition/fuel related. Pull the codes and report back. Pray it's not a code 16.
Old Jul 15, 2006 | 10:16 PM
Steelman's Avatar
Steelman
Default Opti problem
I had a similar problem. It finally died and with only 1000 miles on a new Opti. The car was stored over a long period (autocross car). Unfortunately, sitting around doesn't help. The problem was corrosion at the connector going in to the Opti. After taking everything apart on the front of the engine and getting into the Opti we found the culprit.
Labor was excessive, but parts were minimal. Unfortunately, GM decided that putting the distributor in the front of the block was, in their opinion, a good idea.
That reminds me of the old flat head fords, which worked longer than our Optis. If you can, get in there and clean the contacts and you may be whole again. Otherwise, get an MSD replacement.
Ralph
Old Jul 15, 2006 | 10:21 PM
aminnich's Avatar
aminnich
Or 36 (hi resolution)
Old Jul 16, 2006 | 11:55 AM
Fast Eddiz's Avatar
Fast Eddiz
I had just installed a new opti when, with less than a few hundred miles, I started having similiar engine problems to when the opti was bad. Turned out to be a bad coil.
Old Jul 16, 2006 | 06:43 PM
90 Convertible
Well my buddy came over yesturday and the only code it would pull is a bad temp sender (keeps showing -40 degrees). Even though we let the car sit and idle for 10 minutes then it stumbled and died, no other codes. Car also wouldn't start back up afterwords because of a lack of spark. However if we let it sit for about 10 minutes it would start back up. Let it idle again for about 10 minutes and it died again, still no codes.
Checked the coil wire and found it was loose so I fully seated it. Then we went and pulled the #1 wire and had it form a arc to a ground to check for spark with the car running, hoping to see if car stalled out it would be from a lack of spark. Car idle for 30 minutes and wouldn't repeat symtoms. Maybe seating the coil wire all the way fixed the problem, but who knows.
I am going to rewire the digital 6 since the previous owner did a hack job with bare wire hanging out of the butt connectors but I have to wait until I can get a new Coil plug for the harness as they didnt leave much room.
I will report back if the problems arn't solved.
Old Jul 16, 2006 | 11:46 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
The CTS can cause a lot of trouble and cause eratic engine operation.It is a common cause of your troubles.Fix or change it.
To Is my opti going out?
