85 with 23 -42-44 codes
Old Jul 17, 2006 | 07:19 PM
black85vette's Avatar
black85vette
Default 85 with 23 -42-44 codes
I changed the intake and now getting these codes. should I fix the first code and then reset the ECM and try again?
Old Jul 18, 2006 | 01:55 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Make sure the IAT is where it belongs (or as close to), and make sure its connected and not damaged. Next, check your ICM is connected and make sure the wires arent damaged, then check your O2 sensor connection. Also check that the ECM is connected and the plugs are fully in. Then disconnect the neg terminal for a while to reset the codes. Id say either you have a damaged wire somewhere, a bad ground, or the plug in the ECM is loose.
