LT1 Balance Issue
Old Jul 18, 2006 | 03:35 PM
STL94LT1's Avatar
STL94LT1
Default LT1 Balance Issue
Say I bought a used LT1 engine that didn't have the flywheell/flexplate. How could the engine be balanced with the new flywheel? Or, would the rotating assembly have to be rebalanced?
Also, if the LT1 had an M6 flywheel that was with the engine. But, the engine was going in an A4. Could the flywheel-flexplate be matched balanced?
Old Jul 18, 2006 | 04:03 PM
bogus's Avatar
bogus
without the flywheel, yes, you would have to get the rotating mass rebalanced.
as for the flexplate, I am not sure...
however, I would not be surprised if the torque converter, being full of fluid, acts as a hydraulic dampner.
Old Jul 18, 2006 | 05:11 PM
FELNGR8's Avatar
FELNGR8
You wouldn't have to tear down the engine engine to have the rotating assembly balanced. There is a factory procedure to insert the balance weights into a flywheel while in the car to achieve proper balance. Bluewasp has posted the procedure on here before. If you PM him he might email you a copy.
Try reading this post by Bluewasp
http://forums.corvetteforum.com/show...hlight=balance
Old Jul 18, 2006 | 06:08 PM
STL94LT1's Avatar
STL94LT1
Thanks guys.
To LT1 Balance Issue
