What size gear??
Old Sep 3, 2001 | 09:07 PM
93vetteguy's Avatar
93vetteguy
Default What size gear??
I have a 93 with a LT-1 engine few mod. nothing radical. I would like to know what size gear she has in the back. :D
Old Sep 3, 2001 | 10:19 PM
CROOZN's Avatar
CROOZN
Default Re: What size gear?? (93vetteguy)
either you have 2.59's or 3.07's i forgot the gm codes on which is which, but look at you codes list under your console door someone will tell you which code to look for.
Old Sep 4, 2001 | 08:45 AM
GUMPA's Avatar
GUMPA
There is a 2:73 listed also.
Altough most came with the 2:59's on LT1 Auto which is RPO GM1.
G92 Perf. axle is either 3:45 or 3:07
The best gears for LT1 Auto seem to be the 3:73"s, but only if you like to "Rock & Roll" :yesnod: :reddevil :yesnod:
Old Sep 4, 2001 | 06:32 PM
jay17's Avatar
jay17
Default Re: What size gear?? (GUMPA)
Hey GUMPA, what's your rpm's at 70-75mph?
Old Sep 4, 2001 | 08:33 PM
LUDS 96's Avatar
LUDS 96
It is stamped on the bottom of the rear end on the nose of the housing. You can read it if you put the car on some ramps or a lift. :seeya
Old Sep 4, 2001 | 08:38 PM
NoWorries's Avatar
NoWorries
Gumpa, I believe the 2.73 only came in convertibles.
To What size gear??
