Quick oil cooler question
Old Jul 20, 2006 | 11:58 AM
ethan1321's Avatar
ethan1321
Default Quick oil cooler question
I was doing an oil change today and thought I would try and plug an oil leak around where the cooler mounts to the block. When I took it off I found no gasket or O-ring, is that correct? I can't imagine there isn't supposed to be something in there. I haven't been able to find any info, can somebody help me out that has had it off?
Old Jul 20, 2006 | 12:23 PM
jimmers's Avatar
jimmers
I just replaced mine this year and there should be a gasket between the oil cooler and engine block.
Old Jul 20, 2006 | 12:40 PM
ethan1321's Avatar
ethan1321
Thanks for the info. Where did you get the gasket at? I have checked the local autoparts stores and can't locate one. I was just thinking of putting a gasket from an oil filter in there seems like it should work.
Old Jul 20, 2006 | 01:31 PM
scott89's Avatar
scott89
I bought mine thru Ecklers (1989 L98)
Old Jul 20, 2006 | 01:35 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
How bout a dealer?
Old Jul 20, 2006 | 01:59 PM
ethan1321's Avatar
ethan1321
I'll check Ecklers website and give the dealer a call. After I got all the dirt wiped off of it there was a gasket in there but it was completely smashed down. Thanks for the help.
Old Jul 20, 2006 | 02:01 PM
Pete K's Avatar
Pete K
This is the answer. Thicker than factory gasket and works like a charm. Can't beat the price either
To Quick oil cooler question
