What do you think about this Engine?
Its rated at 520hp @6200 and 490lb/ft @4000
11.5:1 compression
Block: Thermally cleaned and Stainless Steel Shot. Inspected by MPI process. Decked, bored, honed with torque-plates and pressure washed. Clevite cam bearings and pioneer brass freeze plugs installed.
4-bolt main caps and ARP main studs.
Crank: Eagle 4340 forged steel 3.875” internal balance
Rods: Scat 4340 forged steel, 6” length floating pin.
Pistons: SRP forged
Rings: Speed Pro Plasma-Moly
Bearings: Clevite Main and Rod Bearings
Core Plugs: Brass Pioneer core plugs
Main Studs: ARP Performance main studs
Lifters: Comp Cams Hydraulic Roller
Pushrods: Comp Cams High Energy
Valve Springs: Comp Cams
Rocker Arms: Comp Cams Pro Magnum 7/16 Full-Roller 1.5 Ratio
Timing Set: GM LT4 roller timing set
Timing Cover: Recon Aluminum timing cover
Oil Delivery: Melling high volume pump, pickup tube and HD Drive
Oil Pan: New factory 5-quart
Gasket Set: Fel-Pro Performance
Head Bolts: ARP Performance Hex Head
Cam Manufacturer: Comp Cams
Type: Hydraulic Roller
Operating Range: 2300-6300 RPM
Idle Quality: Good
Duration: Intake: 236˚@ .050”
Exhaust: 244˚@ .050”
Lift: Intake: .585”
Exhaust: .580”
Lobe Separation: 112˚
Heads: Trick flow 195cc LT4 Aluminum Stage 2 Porting, Five Angle Performance Valve Job
Combustion Chamber: 64cc
Intake Runner: 195 cc
Intake Valves: Stainless Steel 2.02”
Exhaust Valves: Stainless Steel 1.60”
What did they have on the motor when they rated it? that would be my next question.
It was featured in August (this month) of GM High-Tech Performance.
It made 521hp and 487lb/ft on an engine dyno, using the Trick Flow LT1 195cc heads and a LT1 intake.
I really like the engine, but I dont want to spend that much.
Is a forged crank really necessary for those power levels?
This engine is making 1.3 HP/cu inch. That is a very healthy street engine. I would not cut any corners in order to drop the price a few hundred dollars. Engine failure is far more expensive. I am sure you have heard the old saying, "Speed costs money, how fast do you want to go?"
Seriously, Golen's prices are not out of line for the quality and performance they deliver.
I wish I understood that. It had a 3000 stall converter. Thats a 25% drivetrain loss. But it did make the 520 on the engine dyno, so the car was really experiencing a 25% drivetrain loss, or between the tune from the engine dyno and car dyno was pretty different.
If it wasnt for the engine being dyno'd on a engine dyno, I would be really worried about what that engine made given just the car dyno results.
I guess they just chose the wrong car to put it in to show off the engine.
equipment hooked up such as alternators, power steering, power brakes, full exhaust (mufflers/converters), plus it takes power to turn a converter, transmission internals, driveline, rear-end gears, axles, tires before the power ever gets to the ground at the rear wheels.I used to estimate 80-hp as a rough amount of HP being absorbed by all this. Maybe that is not realistic anymore (ie: 520 - 80 = 440). Plus, you can bet the manufacturer has tuned the engine to a very fine point before they publish dyno figures. However, I believe it has become somewhat common to under report a crate engine's power in order to avoid consumer law suits. So you are right, 400 seems a bit low. But the 520 is probably a repeatable number.
, But looking at that combo the 400 RWHP in an auto seems a bit closer to what I have seen for that cam/head combo.
