Corbeau Seats in a C4
Old Jul 20, 2006 | 02:12 PM
Vestor's Avatar
Vestor
Default Corbeau Seats in a C4
Has anyone been able to get a Corbeau CR1 seat into their C4? Corbeau recommends the A4 seat, but I'm not sure I like that as much as the CR1.
http://www.corbeau.com/products/cr1/cr1.shtml
Thanks for the help.
Old Jul 20, 2006 | 05:11 PM
cplonner's Avatar
cplonner
Old Jul 20, 2006 | 10:52 PM
hurricanejames's Avatar
hurricanejames
I can't speak from experience but from what I've heard, those particular Corbeau seats, although offered for the C4, don't fit in the car very easily. The latches on the side of the seats prevent it from fitting in the seat wells which are already quite cramped. Of course I may be wrong, but I took the safe route and used Corbeau Forzas...They fit great, look great in my opinion, and were respectably priced. They do not, however, have any adjustment to speak of. Not much room for that, anyway.
Old Jul 21, 2006 | 12:26 AM
Vestor's Avatar
Vestor
Hurricane,
What do you do about seat belts? I'd like to be able use both my stock belts and a harness. Are you able to use your stock belts with the Forza?
Thanks for the info.
Old Jul 21, 2006 | 01:40 AM
hurricanejames
The stock seat belts work just fine-They're not impeded by the seats at all...I have a 5-point harness set-up that I use with a DRM roll bar. Day to day I use the stock belt, simply easier to get in and out of. But went I get the urge to rip, I use the 5-point...Very snug and secure, you're not going to move around much. If you listen to some on this board, the Corbeaus don't compare to the vastly more expensive Sparcos and the like...To each his own; the Forzas were a pleasant surprise to me when they arrived. Very well-built in my estimation, Corbeau sells a slider/bracket that fits the C4 perfectly making it a true bolt-in proposition.
Old Jul 21, 2006 | 07:22 AM
Arlon's Avatar
Arlon
Are the padded enough to be comfy for a long ride?
Old Jul 21, 2006 | 03:10 PM
Vestor's Avatar
Vestor
Hurricane,
Thanks for the info. Man it just doesn't seem like the stock belts would still work with those high lateral supports. Do you tread the stock belt though the belt opening in the seat or over the top?
You don't happen to have a picture do you??
Thanks again for the info.
Old Jul 21, 2006 | 03:16 PM
billybonesmusic's Avatar
billybonesmusic
those seats are schweet! ill be watching this one to see how it pans out, I have an 84 that is in bad need of seats (along with all esle) lol
Old Jul 21, 2006 | 03:51 PM
tequilaboy's Avatar
tequilaboy
I also have the Forzas.
I run the stock belts over the top of the lateral supports. It works ok.
If you're really thin the belt might not really contact you, that would not be good. This shouldn't be an issue for most Corvette drivers.
Fitting into the Forzas might be a problem for some (if much over 200 pounds).
If I were doing it again, I'd probably opt for the FX1-PRO. It appears (from the pictures anyway) to be flatter across and less intrusive in the belt area.
Oops, posted wrong link the first time.
http://www.corbeau.com/products/fx1pro/fx1pro.shtml
Old Jul 22, 2006 | 07:51 AM
hurricanejames
For me, the seats work just fine...They've been in my '86 for three years and wear like iron. You will find the seat puts you in an upright position perfect for performance driving, but you really can't 'slouch' in the seat. You can shim the front of the slider brackets a bit with washers to give a small bit of recline to your driving position. I drove to DEI in Mooresville, N.C. from Pittsburgh two years ago and had no trouble whatsoever. Tequila's right though; if you have much over a 36" waist it'll be a tight fit. I'm totally in the dark with the picture thing, but if i can get up to speed here I'll attempt to post pics.
Old Jul 22, 2006 | 08:58 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I do know that MAM offered the CR1 for installation in the C4 at one time. They were only in the catalog for several months, so there may have been complaints about the fit.....
Larry
code5coupe
Old Jul 22, 2006 | 04:36 PM
Vestor's Avatar
Vestor
Larry,
I notice that MAM pulled them out of the catalog after only one or two runs. The CR 1 is a wider seat. From my messurements, it looks as though it will fit, but I guess at the actual time of install it must be a problem.
I'm getting the feeling that any fixed back seat is the way to go for clearence.
Sparco has a great looking fixed back for the street.
http://www.sparcousa.com/pseats_street.asp?id=199
You can see that it has a low area on the lateral support for belt clearance...neat idea, not sure why more fixed back street seats aren't like this.
Only problem is the seat is $639/ea. Not sure if I'm ready to put down $1500 on seats by the time I get the adaptors in.
Love to see some pictures on any installs of seats.
Thanks,
Gregg
Old Jul 22, 2006 | 11:59 PM
rocco16's Avatar
rocco16
$150 APC Rally/Race seats....
http://img132.imageshack.us/img132/1714/0000247hy8.jpg
For the money, you can't beat 'em.
Larry
code5coupe
Old Jul 24, 2006 | 05:27 PM
Vestor's Avatar
Vestor
Larry,
Those Seats look great and seem to fit very well. I see that they come with a slider mounted on the seat already. Were you able to mount slider on the existing tracks or did you need to get an aftermarket kit. I see that they offer them with "Wedge Brand" adaptors. Let me know how difficult they were to install.
Thanks so much. I think I've found what I'm looking for.
Gregg
Old Jul 25, 2006 | 09:34 PM
rocco16's Avatar
rocco16
Gregg, you have a PM.
Larry
code5coupe
Old Jul 26, 2006 | 10:01 AM
Arlon's Avatar
Arlon
Larry, what model of seat did you use? Also sent a pm your way.. Arlon
Old Jul 27, 2006 | 08:35 PM
rocco16's Avatar
rocco16
PM answered, Arlon.
APC Race seats...see post #13.
Larry
code5coupe
To Corbeau Seats in a C4
Old Jul 27, 2006 | 10:10 PM
TankerVette's Avatar
TankerVette
those look nice... think the will work with my 300lb rear end?
Old Sep 13, 2006 | 08:26 AM
anesthes's Avatar
anesthes
Maybe. I just bought a set. Pep boys stocks them for the same price as Summit, and you don't have to pay shipping.
I'm mounting mine to the factory power bases. Looks like the APC base bolt pattern is a little wider than the factory base, so I'm going to need to use some flat stock.
-- Joe
Old Sep 13, 2006 | 05:28 PM
Caliburn's Avatar
Caliburn
Any of you guys with the aftermarket seats get any more headroom out of them? I know for a fact I can't lose any headroom - I scrape the roof with a helmet no matter how I adjust things. It would be nice to know if any of these seats mounted a little lower - and I could definitely ditch the power controls if it meant some more headroom.
