New brake fluid, how important is it??
Old Jul 20, 2006 | 02:30 PM
mn_vette's Avatar
mn_vette
Default New brake fluid, how important is it??
Hey guys, I've been doing some random reading in the tech section and it dawned on me, I've never changed my brake fluid. And from the way I got the car I'm guessing that it has never been done. So that's 13 year old brake fluid.
I purchased a set of speed bleeders this morning, but I'm wondering is there any performance benofit to doing this? Will my braking improve with newer fluid? And is there any special kind of fluid that you would recommend other than the basic DOT3?
Old Jul 20, 2006 | 02:41 PM
Pete K's Avatar
Pete K
I like the ford fluid
Old Jul 20, 2006 | 02:45 PM
mn_vette's Avatar
mn_vette
Pete, I think you missed the questions above, obviously it has to be done and is way over due
Old Jul 20, 2006 | 02:49 PM
Pete K's Avatar
Pete K
yes braking performance will inprove. Parts will last longer too.
Old Jul 20, 2006 | 03:03 PM
mn_vette's Avatar
mn_vette
Thanks that's what I was looking for
Old Jul 20, 2006 | 03:33 PM
Sidney004's Avatar
Sidney004
Not to mention with speedbleeders, it is very, very easy to get a real good bleed with a very hard brake pedal. Personally, before speedbleeders, every time I bled the brakes it was worse than before. DOT 4 with the highest wet boiling point would be a good fluid to use. I use Motul 600.
Old Jul 20, 2006 | 05:41 PM
DonF's Avatar
DonF
That is what I use, after I bleed the fluid out & it is good & clean I keep it that way. At least once a year I do this. That might be a little much but it is cheap enough.
Old Jul 20, 2006 | 06:36 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Actuallly, considering the cost and complexity of various components, it isn't too wacky to do it once a year, if only to "save the equipment."
BTW, that kinda goes for other things, too, like the trans, the diff, the radiator, the PS. That old saying, it can't hurt, really applies. I figure it this way: if you do everything you can to prolong the equipment, and it still goes out, it's not as if you didn't try.
Old Jul 20, 2006 | 06:38 PM
bogus's Avatar
bogus
I recommend Valvoline Synpower Brake Fluid. Great stuff. Works great in the clutch hydraulics, too.
As for the effects... oh, yes. The pedal will feel better, and you won't get anymore soft pedals from repeated hard stops.
Old Jul 20, 2006 | 07:15 PM
jimmers's Avatar
jimmers
Old Jul 20, 2006 | 08:44 PM
Bob CTS's Avatar
Bob CTS
I have it in everything I own, Valvoline Synpower Brake Fluid is the best I rate it next to the 'Right Stuff'
Bob
Old Jul 20, 2006 | 09:08 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
new fluid id a great thing to do
i finised mine a few weeks ago
Old Jul 20, 2006 | 09:14 PM
mothersworry's Avatar
mothersworry
Valvoline Synpower Brake Fluid is the way to go for street driven applications. Brake fluid is hygroscopic, meaning it attracts water like desiccant in an air conditioning receiver-drier. This moisture can attack calipers, wheel cylinders, and more importantly, expensive ABS components. Brake fluid can be tested by means of electronic instruments or simple dip-type test strips. If your brake job doesn't require any hydraulic component replacement, you may want to test and/or replace the brake fluid. If any hydraulic component is being replaced, it would behoove you to flush and bleed the entire system.
Follow the link to StopTech's website
http://www.stoptech.com/tech_info/wp...edbrakes.shtml
Old Jul 20, 2006 | 11:03 PM
mike t's Avatar
mike t
Last saterday I set out to visit my daughter 150 miles away in the middle of NH and at the first stop not far away my brake pedal went almost to the floor, not a good thing. So back home, up on jacks, off with wheels and found brake fluid on the inside of both rear wheel rims and weeping out of the bleeder nipples. Hardly any fluid left in the master cylinder, big time air suck. Despite the fact that there is extensive procedure outlined in the owners manual reguarding removing air form the master cylinder I purchased a mityvac and sucked 2 containers of motul 600 through the system. Starting at the wheel close to the master cylinder and ending with the farthest away. Found lots of air which the mityvac sucked out. The thing was a God send and you can work alone. The pedal is now solid, put teflon tape on bleeder screws will see if this works. Have new calipers on way from VP. Just have to try and figure out that handbrake system Though I did upgrade the brake system last year with new rotors and pads and fluid, the brake fluid did look old, so once a year fluid change is not a bad idea
Old Jul 21, 2006 | 07:30 AM
runner140*'s Avatar
runner140*
Try Valvoline synthetic, and buy a quart, its not expensive. Should be changed (complete flush) once a year if you drive alot. With your speed bleeders its a simple job and you will see a difference.
Old Jul 21, 2006 | 07:38 AM
mseven's Avatar
mseven
The way I see it is, brake fluid is clear not coffee color....
Old Jul 21, 2006 | 01:56 PM
Vetracr's Avatar
Vetracr
Don't use Motul 600 on a street car if you live in a humid environment. Motul 600 is great for the track because of its high dry boiling point but you don't change fluid every time you drive on the street. Motul is very hydroscopic, it holds water, fine for the bay area but not in the East or South. Use the Ford stuff for the street. By the way, it won't make your brakes work better. It will just make it a little more difficult to boil the fluid under hard use.
Larry
To New brake fluid, how important is it??
Old Jul 21, 2006 | 08:52 PM
mike t's Avatar
mike t
Did not know this and sound advice plus cost is an issue. My C4 is street only will take a good look at the ford fluid. Thank you.
Old Jul 22, 2006 | 01:59 PM
billybonesmusic's Avatar
billybonesmusic
synthetic brake fluid is a nice way to go, it wont be a magnet to water as bad, i think it is dot 5? will save your brake components in the long run. by government specs, it should all be compatable.
Old Jul 22, 2006 | 04:06 PM
the blur's Avatar
the blur
contary to popular belief, Ford fluid sucks. It sucks water real fast. look at the specs. It's not for a street car. it's for a maintained race car.
and if your doing this in a street car, get DOT3, as it will last longer. not as hydroscorpic.
