An L98 will hum along at 2600 all day long without issue. Its just a little louder. I had to drive my car a week to work without O/D (550 highway miles at that time).
i know it will hum with my 1 3/4 hookers. i just made a point that it sucked back the gas, and it was annoying at best! scorp would you agree that the 4+3 is better for topend then the ZF6. Meaning the 4OD is better then the ZF6 5th gear because of the ratio. BTW, Did you ever get your car tuned?
Depends on what you mean by "better".
4+3 4th/OD = 0.68 or 0.60
ZF6 5th = 0.75
4+3 rear end = 3.07
ZF6 rear end = 3.42
Final for 4+3 = 2.087 or 1.842
Final for ZF6 = 2.565
The 4+3 has a theoretical higher top speed, but the ZF6 is going to pull theirs easier in most cases.
*edit*
car not fully tuned, life is too busy and needs a fuel pump.
