1-2 shift not happening when supposed to
Old Jul 20, 2006 | 10:51 PM
racer tony's Avatar
racer tony
Default 1-2 shift not happening when supposed to
my 94 will not shift properly into second gear at wot. despite lowering the shift points it still goes to around 5500 - 5700 rpm and it acts almost like a rev limiter and bounces back and forth, then I instinctively let off the gas and it shifts to 2nd. The motor is a 383 with a rev kit and fuel shutoff is at 6500. normal mode 1-2 shift point is 31 mph, rear gear is 3.07 with 285 40 17's..... anyone come across this before? btw the trans was rebuilt.
Old Jul 20, 2006 | 11:26 PM
Pete K's Avatar
Pete K
The servo apply pin is selective length. It is possible the pin is too short, preventing proper pin pressure on the band. Band is applied for 2nd and 4th gear.
Old Jul 21, 2006 | 12:05 AM
racer tony's Avatar
racer tony
that is a possibility, we had the guy who rebuilt also install a billet (sp) servo from ati. i wasnt there when he rebuilt it so anything maybe a possibility, my first instinct was something computer controlled, it being a 4l60e and all
Old Jul 21, 2006 | 08:07 AM
Pete K's Avatar
Pete K
This could be the case. Many things can cause the symptoms described. You can check the servo by pushing firmly on the cover. It should move approx .040-.100. Over 1/8 inch is surely a pin that is too short.
Old Jul 21, 2006 | 11:58 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Listen to him he is the MASTER!
Thanks,Matt
Old Jul 21, 2006 | 06:29 PM
racer tony's Avatar
racer tony
it would appear that way, i shall listen to his words of wisdom
Old Jul 23, 2006 | 08:23 PM
racer tony's Avatar
racer tony
ok tell me if i did this right, since i cannot get my hand onto the servo with the exhaust system in place, i grabbed a small pry bar and gave it a push, the servo moved more than an 1/8th inch or so it seems to my eyes... should i have not used a pry bar or just used barely any force?
Old Jul 23, 2006 | 08:29 PM
Pete K's Avatar
Pete K
Using a pry bar is ok. The cover pushes a pin. The pin pushes the side of the band. The band clamps the drum. The pin is selective length to make an initial adjustment that "should" be good for the life of the band.
Old Jul 23, 2006 | 08:32 PM
racer tony's Avatar
racer tony
so since its moving more than 1/8" i should more than likely have the servo pin replaced with the proper length, and more so make the guy who rebuilt it, do it again.
Old Jul 23, 2006 | 08:38 PM
Pete K's Avatar
Pete K
If it is a recent rebuild, I would politely question him about it. I am not saying you positively found your problem, but you may have. Most trans techs do not check the pin length because it requires a $400 dollar tool to do it. From the factory the correct pin is matched to the case. Most guys believe that if the pin and case stay together, they will be fine after a rebuild. Aftermarket bands can vary in thickness.Combine this with a worn drum, and they can be assembled loose, even after a fresh build.
I check and set each and every one to avoid this possibility. Hopefully, your guy did as well.
Old Jul 23, 2006 | 08:39 PM
Pete K's Avatar
Pete K
"If" the band was loose as a result of an improper set up, the band is likely burnt. Hopefully this is not your problem.
Old Jul 23, 2006 | 08:42 PM
racer tony's Avatar
racer tony
well i hope so too, i have no idea why this trans is acting the way it is at WOT, its got me boggled
To 1-2 shift not happening when supposed to
