If you've got a torque motor to support it, build a damned TH350 (or 400 if you want to be complicated) and knock your gear ratio down and forget about the damned OD... Just my $.02
-Jeb
$1,000-, $1,500 will buy alot of quality for either one. You can spend less and still get a good unit. A near stock 400 will support 700 or more hp
Although the turbo 350 has a reputation for being the greatest 3 speed of all time, I have seen alot of failures. They are a good trans, don't get me wrong. Just not the end all for 3 speeds.
You know...Another tranny that hardly EVER gets mentioned in regards to C4 swaps is the 2004R... A shame really, it's size and efficiency is that of a TH350 and when built correctly they will take an unhealthy amount of abuse... I had a 9 second turbo Buick with one of Mike Kurtz's 200's in it... Damned car weighed 3850 lbs with me in it...
-Jeb
-Jeb
I hear it's not very cheap and not worth the hassle. At least that what I read on the Fbod forums about'em.
Built a 700r4 it will last atleast 10 or less 10 second runs.
Ask me how I know
Spend the money on the 4L80E and fab the c-beam with a 6 inch 4L80E tail shaft and lengthen the c-beam
or the 9 inch tailshaft and shorten the c-beam.
Cut the floor board and install a mount and it should never break.
-Jeb
"I just want to run 10's N/A"
Broadbased assumption you won't be looking for O/d on your 10 sec run so as Jeb said either trans built up will do fine.
At a minimum you need adapter made to mount the
C beam to the trans ext housing and a modified driveshaft.
