Best C4 for the strip?
Old Jul 22, 2006 | 10:27 PM
tlaselva's Avatar
tlaselva
Default Best C4 for the strip?
Contemplating a C4 that I can configure for the stip.
Have aspirations of installing a big-bock, with a solid axle, auto etc.
Is there a preferred year C4 for modifying into a serious strip racer?
All opinions welcome.
Old Jul 22, 2006 | 10:36 PM
FELNGR8's Avatar
FELNGR8
The cheapest and lightest car, an 84 or 85. This assumes you will gut the interior and throw away the motor and transmission as part of your build.
Old Jul 22, 2006 | 11:17 PM
Z06_BluByU's Avatar
Z06_BluByU
No sense in buthering a perfectly good L98, Lt1, LT4 or LT5.. I would say a '84 is the ideal year.. plus I think they all had dana 44's and are pretty light!
Old Jul 22, 2006 | 11:24 PM
AKS Racing's Avatar
AKS Racing
I think it was the other way around, the '84s all had Dana 36s. Not positive though.
Old Jul 22, 2006 | 11:26 PM
Idburnu's Avatar
Idburnu
84 would be ideal due to lower cost, but no 84 had the Dana 44. Wouldn't matter for what the OP wants to build anyway though.
Old Jul 23, 2006 | 12:28 AM
Z06_BluByU's Avatar
Z06_BluByU
I stand corrected....
Old Jul 23, 2006 | 01:44 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
The 84 would be my vote. All 84's had a dana 36 but it doesn't matter with your plans. You can buy a nice clean 84 for cheap.
Old Jul 23, 2006 | 01:57 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
84-85 since there wasn't any ABS, it's one less thing to worry about.
If you are going full blown, any wrecked vette is a good candidate, but if you are doing a gradual build, any non wrecked vette would suffice.
Old Jul 23, 2006 | 01:27 PM
vader86's Avatar
vader86
If you go with an earlier car that hasnt been parted out or wrecked, you will probably want to switch its rear spring out for a softer one.
Old Jul 23, 2006 | 01:51 PM
Bruce's Avatar
Bruce
I would start with a 85. Remove the ac system and what ever you will never use, need the space for the hair dryer and related pipings. Replace the motor with a built one 383ci or 401ci motor and fitted with a 91.5mm turbo and an aftermarket engine management. And spent a lot of $ to beef up the rear end, suspension, you set to go out racing..... This combo will beat the Big Block N/A setup to death.
Old Jul 24, 2006 | 01:57 AM
sami85L98's Avatar
sami85L98
85 vette with 420 forged sbc, solid roller cam, dana 44, mini ram, 3500-4000 stall TC non lockup, TH350 or any 3 speed auto tranny, u dont need lockup, Brodix race rite 200cc heads and goes on ......
To Best C4 for the strip?
