Reman Dana Questions
Old Jul 23, 2006 | 12:37 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
Default Reman Dana Questions
How do you remove the yolks from the rear end of a dana 36 ? I can pull a center chunk but the reman units do not come with the yolks in them. Is this a giant p.i.t.a. that requires special tools etc ? I have a buddy who bought a reman dana 36 for his car and I told him I would help him install it. So we're going to have to pull his center and yolks out of it for the reman unit and reinstall. I hope I am calling these by the proper name. I am talking about the pieces that the half shafts bolt to. There is one on either side of the center chunk. Anything we should know about swapping yolks ? Thanks in advance.
Old Jul 23, 2006 | 08:19 AM
WVZR-1's Avatar
WVZR-1
Default Side yokes
"side yolks" as you call them will be no problem. A pair of "stout" snap ring pliers will do the job. When you fit the "short axles" or "yokes" you need to check end play. Needs to be .0005 to .0085 The snap rings are selective but builders generally use what they took out. You would like to be on the tighter side of the tolerances.
You "DO NOT" need to remove the roll pin and the differential shaft to get to the snap rings.
Old Jul 23, 2006 | 07:36 PM
wayne lowry's Avatar
wayne lowry
Snap ring pliers are what you need. I can lend a hand and snap ring pliers if needed.
Old Jul 24, 2006 | 02:14 AM
JD'S WHITE 93
I found some good pictures online. Wayne, if you want to lend a hand that would be great. I've never met anyone from the forum before.
Old Jul 25, 2006 | 06:43 PM
JD'S WHITE 93
Swap is done, thanks for the help. I now got a Dana 36 for sale on the forum !! $125.00 complete with gears, posi unit and all. My prize for doing the swap.
Old Jul 25, 2006 | 08:48 PM
aminnich's Avatar
aminnich
Just for what it is worth (not much) yolks are in eggs, yokes are in cars.
The parts you refer to are actually called axle shafts. Those are some stout and PITA snap rings aren't they? I am slowly doing a D36 rebuild and even with Snap-On brand snap ring pliers they are a PITA. Glad you got it done. I am sure you added the GM posi lube additive, but of course you knew that.
To Reman Dana Questions
