air conditioning fan motor
Old Jul 23, 2006 | 12:25 PM
Vettewood's Avatar
Vettewood
Default air conditioning fan motor
Has anyone had problems with AC fan motor continuing to run with key switched off. Had to disconect a plug i think at the fan motor. Is there a part that can be replaced to fix this.
thanks
Old Jul 23, 2006 | 12:46 PM
jfb's Avatar
jfb
Remove the control head in the dash and unplug it. If your a/c blower still runs then you have a defective blower control module. In the module is a power transistor which has likely shorted and can be replaced if your ohmeter proves this to be the case. Or you can just replace the blower control module. If the a/c blower doesn't run, then you have your problem with the control head and it should be replaced.
