Factory lock nuts
Old Sep 4, 2001 | 12:42 PM
MelloYellow87's Avatar
MelloYellow87
Default Factory lock nuts
I recently purchased an 87 coupe... I need to change the brakes, but was not given the key for the factory lock nuts.. Is there any way to get a new key and if not what would be my options to get these lock nuts off????
Old Sep 4, 2001 | 01:05 PM
vette87's Avatar
vette87
Default Re: Factory lock nuts (MelloYellow87)
Options are none that I know of, the lug has an adapter that fits the slots on the top of the lug nut. I would check with Chevy parts, Ecklers, Mid-America or Corvette Central maybe they carry the part. If you need it real bad though maybe I'd break down and pay Chevy, you need it in a hurry any way in my opinion. What are you going to do if you get a flat?? you'll really be stuck.
Old Sep 4, 2001 | 01:27 PM
Wheelman's Avatar
Wheelman
If you were like me, the key was lost, and if you dont really care about the lug nuts, take the car to a good tire shop and they can break them off with a impact wrench.
Old Sep 4, 2001 | 02:05 PM
skilawyer's Avatar
skilawyer
hammer a deep socket on over the nut and break it loose with an impact or large breaker bar. a tire shop has the tool, but will probably cost you.
Old Sep 4, 2001 | 02:07 PM
scorp508's Avatar
scorp508
Default Re: Factory lock nuts (skilawyer)
That is what I did mine with. Chevy dealer wanted about $150 to do them (with a chisel!! :eek:)
Old Sep 4, 2001 | 02:54 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Try these guys:
http://www.mcgard.com
They make the one's to fit my 89 and perhaps the 87 as well. Cheap too.
Good Luck,
Pete
Old Sep 4, 2001 | 03:13 PM
TJR's Avatar
TJR
I'd bet that Chevy could order a new key according to your VIN. Did you look everywhere for it? It is supposed to be in the passenger side rear compartment clipped to the lug wrench.
Old Sep 4, 2001 | 10:22 PM
GGeoff's Avatar
GGeoff
Default Re: Factory lock nuts (TJR)
I also used the hammer and socket method. It was VERY easy to remove the old locks; very fast as well, about two minutes a wheel.
Makes you wonder just how incompetent a thief would have to be for the locks to make a difference.
Old Sep 5, 2001 | 12:53 AM
TJR's Avatar
TJR
Default Re: Factory lock nuts (GGeoff)
I also used the hammer and socket method. It was VERY easy to remove the old locks; very fast as well, about two minutes a wheel. Makes you wonder just how incompetent a thief would have to be for the locks to make a difference.
Hammer and socket method makes plenty of noise in the middle of the night.
To Factory lock nuts
