Lost wheel lock
Old Jul 23, 2006 | 06:40 PM
loflite's Avatar
loflite
Default Lost wheel lock
Help! Lost the factory wheel lock and can't get the wheels off of my '95. Does anybody have any ideas. Have to get the wheels off to work on the car. Thanks.
Old Jul 23, 2006 | 06:43 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Dealers and major repair shops have the key sets to the locks. Call around first just to make sure....tire places, too.
Old Jul 23, 2006 | 06:52 PM
loflite's Avatar
loflite
Stopped at the local chev. dealer and he said that they did not have one and it is not available.
Old Jul 23, 2006 | 06:54 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Check with the "Midnight Auto Supply", they'll have one!
Old Jul 23, 2006 | 07:13 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Once again, the dealers come through for the customer......
Sorry to hear about that; there goes one suggestion. Try the tire stores.
Old Jul 23, 2006 | 07:14 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
19/20mm socket and a hammer
scorp508's Avatar
scorp508
Bang a cheap 1/2" 12-point 13/16" socket onto the lug then twist it off with a breaker bar. Done deal.
Old Jul 23, 2006 | 07:31 PM
dennysZ51's Avatar
dennysZ51
Like every one is saying use a 12 point socket and hammer it on or mig weld a socket on the head. You can also buy the tool from Snap on. good luck. I did the mig weld trick on my Camaro
Old Jul 23, 2006 | 07:39 PM
Corvette Kid
There are tools available through sources catering to the professional that are made for dealing with such matters. As mentioned, tire stores, most garages, etc. should have the tool to remove them. They're also available from roving tool dealers such as Snap-On, Mac, Matco and Cornwell.
Old Jul 23, 2006 | 09:13 PM
VenkmanP's Avatar
VenkmanP
Any tire store should be able to remove them. If you have a relationship with them they will usually do it for free.
You can also get the extractors at any auto parts store.
Old Jul 23, 2006 | 09:30 PM
NT Vettman's Avatar
NT Vettman
I had a similer problem the previous owner lost his. So I went to Sears and bought a set of inpact grade LUG_OUT #947392. There are designed for striped nut and wheel locks. Worked great! Took all my locks of and just put the regular nuts just like the rest of the car
Old Jul 23, 2006 | 09:44 PM
Daddy J's Avatar
Daddy J
Check your owner's manual.There maybe some info. on the lugnut key in there. Look for an attached card.
Here are a couple of places you can call for info:
http://www.amcorlocks.com/default.htm
http://www.mcgard.com/custserv/
You also might call Chris at Superior Chevy- 1-800-728-8267
He is very knowledgable/helpful so he might be able to help you.
Mention you're a forum member.
Old Jul 23, 2006 | 10:37 PM
loflite's Avatar
loflite
Thanks for all the good recommendations. Nothin beats the forum for info.
To Lost wheel lock
