Why unhook vacume hose??
Old Jul 23, 2006 | 11:55 PM
Dave-B's Avatar
Dave-B
Default Why unhook vacume hose??
When checking fuel pressure today on my stock 86 for the first time, it was 46# with the vac line to the reg. hooked up. Un hooked and pluged, it read 36#. First---is the pressure ok?? Second----with the vac pluged,it took 3 min. to leak down to 36#. Then it just stayed at 36# for another 10 mins, so I unhooked the gauge.Why on the form do you say to unhook the vac line and plug to run this test. Whats the diff.??
Old Jul 24, 2006 | 11:02 AM
rick lambert's Avatar
rick lambert
First off, your fuel pressure is fine, although I usually leave mine attached for about 1/2 hour to watch the bleed off. The second part of the test is for checking the health of the Fuel pressure regulator.
Old Jul 24, 2006 | 11:08 AM
RRT vette's Avatar
RRT vette
The 46 psi with the FPR vac connected it high to me. When the FPR vac is off it should read 5 psi higher than with the vac connected if the vacuum is correct neg pressure. Normal fuel pressure for a 86 is 36-40 psi vac connected and with the vac disconnected it should be in the low/mid 40's. I haven't ever plugged the FPR to check fuel pressure. When you watch for fuel pressure bleed, the engine should be off and no vacuum will be present connected or disconnected.
Old Jul 24, 2006 | 11:51 AM
rick lambert
Funny an 86 would have lower pressure than an 87, the FSM calls out
fuel pressure 40.5-47 psi.
Old Jul 24, 2006 | 01:04 PM
RRT vette's Avatar
RRT vette
FPR vacuum connected or disconnected?
Old Jul 24, 2006 | 01:10 PM
rick lambert
Connected.
Old Jul 24, 2006 | 01:23 PM
RRT vette's Avatar
RRT vette
On my 86E, when you first turn the key the fuel pressure goes to 42psi and when the pump is primed (after 2 sec) the pressure stops at 40 psi. After the engine is started the pressure stays at 40 psi. I am on the high side of fuel pressure for the L98. This is the reason I purchased a AFPR, to decrease fuel pressure to compensate for larger injectors I have. My pressure is at 40 psi engine running and when the FPR vacuum is disconnected the pressure goes to 45-46 psi. From what I remember reading...L98 (36-40) LT1 (40-46). Vacuum connected on all. I consider this normal.
I don't have a way to confirm this right now.
Old Jul 24, 2006 | 06:01 PM
rick lambert
This is what my FSM for 87 says;
"Ignition "ON" pump pressure should be 280-325KPa (40.5-47 psi). This pressure is controlled by spring pressure within the regulator assembly.
2. When the engine is idling, the manifold pressure is low (high vacumn) and is applied to the regulator diaphram. This will offset the spring and result in a lower fuel pressure. This idle pressure will vary somewhat depending on barometric pressure, however, the pressure idling should be less indicating pressure regulator control".
To Why unhook vacume hose??
