Distributor question
Old Sep 4, 2001 | 03:28 PM
TJR's Avatar
TJR
Default Distributor question
I recently replaced plugs and wires, I should have done the distributor stuff while I was at it. Anyway, to minimize down time, can somebody tell me what parts I need before I tear it apart and find out I need more? Just the cap and rotor? (That may sound like a silly question, but I've owned a rotary engined RX-7 for the past dozen years, it has no distributor, all electronic with one coil per plug.)
Thanks.
Old Sep 4, 2001 | 03:34 PM
Dave's_88's Avatar
Dave's_88
Default Re: Distributor question (TJR)
You got it...cap and rotor (for a normal "tune-up").
Old Sep 4, 2001 | 03:55 PM
Paul T's Avatar
Paul T
I about to do the same with my 89, I want to change plugs, wires dist. cap, rotor but I also hear changing the coil to a higher output would improve performance..anyone have a opinion on this, plus what if any is a good one to get...
Old Sep 4, 2001 | 06:52 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Distributor question (Paul T)
I run the HyperTech coil/cap/rotor combo (40% more voltage), TPIS wires, and cut back AC Delcos cut back and gapped to about .045". This combo is worth at least 10HP, gives solid ignition up to rev limit and improves fuel burning for better mileage. Such a deal.
The HyperTech just plugs in, though you'll need to take a Dremel to the retainer ring to get it to fit over the larger top. It still fits under the plenum tail piece nicely. When you have the cap off and the plugs out is a good time to do the wires with minimal hassles.
Old Sep 4, 2001 | 07:37 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
I agree with the posters recommending aftermarket parts. I bought a GM replacement cap and it was made in somebody's basement in the far east and was a piece of junk.
I used a Davis cap / rotor / coil on my 89 and it is quality stuff, but have had some tack problems from the day I did the change.
In retrospect I would keep the stock coil and use aftermarket for everything else.
When swapping caps / coils pay attention to the directions on hooking up the ground strap and other wires. If using high voltage coil you may need nylon screws for the rotor to prevent arching. Reset timing when you are done according to the manual.
BTW, all your plug wire holders are going to break. Might as well get the set from one of the rags so you can hook everything back up. If you go to larger wires get the holders that fit your wire size.
Use anti-sieze from a tube on the plugs. Let the engine get cold before removing the plugs.
Good Luck with the project!
Pete
Old Sep 4, 2001 | 07:56 PM
NoWorries's Avatar
NoWorries
How many miles does the car have on it? If its over 75,000, I would highly recommend taking your distributor out, clean the grease well and refill it.
Its a pretty easy job, it only took me an hour, but I was going slow and I lost the retaining pin and had to look for it. The grease is $6.00, its called, HEI Distributor grease. The only special tool you need is the right size punch for the cam gear, I ground down one of my punches to make the right size.
Other than this, a cap and rotor are must change items.
Old Sep 5, 2001 | 12:06 AM
TJR's Avatar
TJR
Default Re: Distributor question (65Z01)
http://shop.store.yahoo.com/corvette...pm-101-sc.html
This replaces cap, rotor, and coil, right?
Old Sep 5, 2001 | 12:22 AM
TJR's Avatar
TJR
Cool, group purchase on that Hypertech in the Forum Mall, $75.95.
http://shop.store.yahoo.com/corvette...pm-101-gp.html
[Modified by TJR, 11:49 PM 9/5/2001]
Old Sep 5, 2001 | 09:20 AM
tp85's Avatar
tp85
Default Re: Distributor question (NoWorries)
What is there to "refill" on a distributor? What grease are you talling about?
When I had my distributor out to replace my intake manifold gasket, I only put a little assembly lube on the distributor gear prior to reassembly. I have not fired it up yet, so I'm concerned that I forgot something critical.
Thanks.
To Distributor question
