How To Remove - Install Fuel Pump?
Old Jul 24, 2006 | 10:26 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Originally Posted by Da Mail Man
....well dammit!....get that man a beer, a bag of drugs and a hooker!.......
it worked just as you said it would........freakin' yippee!...it is however a very tight fit!.......
ok, now i can sleep tonight....i may keep the hooker just 1 more night!. tomorrow, i'll verify if there is any voltage at the tank filler neck and proceed from there.
Hooray!!!
Be careful checking voltage if you didn't drain the tank entirely. It doesn't take much of a spark to ignite fumes and blow sky high.
Sleep tight. I hope your hooker is.
RRT vette's Avatar
RRT vette
Well freakin right, now you have a way to diagnose the problem ..did someone say beer, drugs, and hooker in the same sentence.
Old Jul 24, 2006 | 10:28 PM
Da Mail Man's Avatar
Da Mail Man
Originally Posted by mseven
Dayam, Sounds like the party is at your house............. congrats
bring your own glasses!....with the way the pump attaches to the assembly and the directions that were given, didn't make sense as to what i was seeing. ps...there was nothing wrong with the directions, just the directed!
Old Jul 24, 2006 | 10:30 PM
Da Mail Man
Originally Posted by skateparkdave
Hooray!!!
hahahhaha....i will separate the filler neck connector (outside of the tank) with the gas cap still in place, and measure voltage that way, thus eliminating any spark/explosion.....
Old Jul 24, 2006 | 10:32 PM
Da Mail Man
well, i have/had a way to diagnose the problem but, needed to prepare in case i had to replace the PUMP. measuring the voltage is easy and i would have done it already but, i got rained out!
Old Jul 24, 2006 | 10:34 PM
skateparkdave
It makes perfect sense to me, but I know it will make more sense as he actually goes through the process.
I didn't see anyone comment about direction of the sock
Ooops. I thought he had said he had the sock all figured out.
What mseven is refering to is the direction of the sock. If you'll look down into the tank with a safe flash light, you'll see a slosh gaurd at the bottom of the tank. This is so you still get fuel with a low tank when turning corners. The sock will have to be positioned on the pump so that it sits down in the middle of that slosh gaurd.
My "sleeve" just slid right off once I had the pump off.
If you look at the pic of my new pump on and lay your assembly at the same angle and mount the pick up "sock" at the same angle you should be ok.
Old Jul 24, 2006 | 10:37 PM
mseven's Avatar
mseven
as far as the direction of the sock, i think you mean the "sleeve" that goes around the pump.
the sock/strainer that "filters" sediment in the gas only comes off one way.........
No, I meant the sock/strainer.
True it comes of one way but can be positioned differently as in direction it has once in the tank.
Mine was hanging on by a couple of threads when I went through this. The FSM, Delco pump etc. stated to remember which way it was positoned and then to complicate things all sources showed the sock in a different direction. I ended up with it in the middle of the "yellow boat" (pointed 12 and 6 oclock) in the tank (if this makes sense).
Old Jul 24, 2006 | 10:41 PM
Da Mail Man
hahah.....ok, we are on the same page. i understand about the direction of the "sock". i thought he was "pulling my leg a bit". i will copy the one in my tank if i have to pull it out to replace the pump.....
Old Jul 24, 2006 | 10:44 PM
Da Mail Man
a-ok!
Old Jul 24, 2006 | 10:46 PM
rick lambert's Avatar
rick lambert
Kinda yeah, when I put my new fuel pump in I positioned the sock pointing toward the left side of the tank..in the middle, if that makes sense. Mail Man...I'm coming to your house, IN MY VETTE, for the hookers and boooooooooooooooooooooooze! I really hope this cures your problem! and AGAIN skateparkdave
Old Jul 24, 2006 | 10:53 PM
Da Mail Man
hahaha........well, we haven't even gotten to the problem yet!.....i have to see if 12vdc at connector....if so, it may be fixed tomorrow, if no 12vdc, i will have to work backwards........
ok, i am otta here for tonight. this thread has been a sister to a very large thread and i hope people will get some info out of it as well as a chuckle or two!...back tomorrow!........thank you everybody for the healp, and i don't say that in passing as i really do mean it!......g'night all!
ps, ya might not want the hooker after she is "done"....awe hell, i'll get ya a "fresh one"!
