need new wiring harness?
Ok now that I finished venting a bit, Would you guys suggest that this could be need of a whole new harness? I dont want to keep replacing the same stuff every 5 months. Most part are already new. The main wiring harness is not. Anyone know where to get a good price on one of these?
The engine harness enters into the interior via a portal on the firewall, behind and below the distributor.
In short, it's a bitch.
The harness is then integrated with the ECU and IP harnesses. This thing is a total cluster ****, if you want my opinion.
Now, what I would suggest, take the convolute off the harness and start to inspect the harness. See what kind of condition it's in. I would not be surprised if the insulation is cracking, splitting, chaffing and otherwise grounding out when it shouldn't.
I have some catalogs that have access to more connectors than you can think of, plus some other links to sources for wire and such.
What happens is that heat, chemicals, etc, all conspire to eat the **** out of the wire insulation. The insulation will shrink and make a total mess of things. This was resolved by the SAE requiring a new material for the insulation.
What I would suggest... and it would give you a lot of functionality, and I think help in many ways... find the end of the harness at the firewall, carefully count all the wires, and get a big *** weatherpack molex connector to create your own firewall harness plug.
From there, start rewiring.
It won't be easy, but when done, it will be a huge improvement. Just document the hell outta the newly constructed firewall junction.
That would suck if when you turned on the lights, the car started...
Im almost to the point now where I just want to pull the engine back out of the car and make it the way I wanted in the first place. A bigger cam, lots of head work done and port my aftermarket base manifold and runners.
Thanks bogus.
it will give you a ton of room at the firewall.
I was gonna send an email, but that ain't turned on, and your PM box is full....
abbogus@yahoo.com
Besides, if either of you are planning on doing performance mods, you will want an ECM from a 1989. It's faster...
Did i just perhaps burn out somthing else now?
Pulling the engine and starting over is sounding really good right now, I can have a new cam put in and my heads worked on too.
But i need to figure out this problem i have gotten my self into.
Thanks for all your help so far.
can you pull codes?
the battery may show 12v, but it might not have the amps... try putting a charger on the battery. Also, be sure the battery terminals are good, and that the main ground isn't corroded.
What happens if you reinstall the paper clip and turn the key on?
I thought mine was a bad battery...then I found all of the cylinders filled with fuel.....
for $150 he will replace conecetors and or necessary wiring, and test the complete harness.
The car now starts up again, I think due to clear the ecm memory by disconnecting the battery.
No codes yet, I drove it for about 10 minutes. It misses alot when the engine reaches operating tempature. So Im expecting it to crap out on me again considering that I havent found much.
At least its running again though.
does anyone have any ideas?
I would begin by ohming the injectors, doing a fuel pressure test, get a noid light and check the injector signals, and have AZ check that ICM.
You may also want to ohm the pickup coil.Most of these test will help eliminate potentials, BUT, I'm really leaning toward the ICM, just because it sounds like the problem comes on after the car hits operating temps.
If you don't have a FSM, that is what I would get next.
I ran tests from the fsm. When it asked to clear codes and see if they come back they dont come back for about a week.
The tests conlude for 36, replace relay. 33 bad maf, replaced maf. And 42 was only there for a day. Im getting the multimeter to test the dist. today.
im going to follow your advice and have the pcm checked too.
I can tell you I was totally shocked when I checked the wires to my fuel pump relay.Soulda been a recall.
