MidAmerica - Graatelli, $499.99
Eckler's - Be Cool - $599.99
Eckler's - Stock - $232.95
The Last Detail - AC Delco - $153.00
Here's the question....what the hell is the difference? I realize that some are 100% aluminum...less weight. However, are the differences great enough to cause me to throw down a few extra bills? :confused:
I'm leaning towards the Delco...is this the same one that came in the '88's?
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Re: Radiators !!!! (Dave's_88)
I just put a BeCool in mine. It's about twice the thickness of the stocker, and it's fully welded alumimum. So you don't crack both plastic side tanks like I did! :U
Actually a little more than that, since you need to buy the spacers as well.
but it's rated for 700hp
I've noticed a lot cooler temp at autocross events.
When I drove into work I left both fans on, manual switch, and my coolant was 177, in town on an 80deg day :D
I haven't been back to an open track yet.
I was suppose to go back to Waterford Sunday, but I got sick! :cry
You make it fit the stock shrowd by cutting the rubber mounts and spacing the fan out.
I took pics, just waiting for the film to develope.
From: And on the fifth day, subpoenas were served to Obama senior staff
The AC/Delco should be the stock radiator that came with the car, but seems too cheap? Ask Sam at TLD if it's the real deal. If it's real, I'd get it in a heatbeat.
If you are looking for an improvement I'd study Griffin.
EDIT: Forgot to add. Throw in some aftermarket corrosion inhibitor extender with the mix of new AF. This will prevent depleating all the silicates from the initial charge of AF onto the new radiator. Use a 50/50 mix of AF to distilled H2O. Flush well prior with clear water, I used distilled on the last flush. Also good time to replace radiator cap and thermostat.
Second Edit: It's tough when you get old (CRS). I would use a Green AF, and use a silicate corrosion inhibitor extender.
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Radiators !!!! (BrianCunningham)
Brian, thanks for the info. I'm looking down the road at this upgrade myself.
