89 won't restart, weak noid light
Old Jul 25, 2006 | 10:08 PM
seenalot's Avatar
seenalot
Default 89 won't restart, weak noid light
My 89 will start fine but when you shut it off, won't restart for a few hours. The car cranks fine so its not the starter. There is spark and fuel. When a noid light is placed on the injector its a weak light.
Old Jul 26, 2006 | 12:40 AM
Sam Lam's Avatar
Sam Lam
Check the resistance of your injectors both hot and cold. The readings on all eight injectors should be very close to each other and between 16 to 17 ohms while hot or cold. Your (and my year) year car has a high failure rate on the stock injectors. When an injector shorts out the resistance drops and that injector will draw higher current. Let me know if you need more info on this.
Old Jul 26, 2006 | 11:48 AM
rick lambert's Avatar
rick lambert
I agree with ohming the injectors...but what would cause a weak light on the noid light...since you do that on the injector pigtail, while disconnected from the injectors...better check connections too.
Old Jul 26, 2006 | 12:20 PM
RRT vette's Avatar
RRT vette
So the injector pulses are good when the engine is cold and weak when the engine is hot. You have confirmed there is fuel pressure and spark are good at this point. Have you pulled some spark plugs to see if they are gas soaked? Also have you seen if the injectors are leaking? The distrubitor sends reference pulses to the ECM, then the ECM calculates these and sends injector pulses to the injectors by grounding them. They are batch fire in the L98, so one side recieves signal at a time. May want to have the ignition control module check out.
Old Jul 26, 2006 | 12:38 PM
seenalot's Avatar
seenalot
The ICM was tested. It was having another problem so its been replaced but problem still exist. Having injectors tested like Sam Lam suggested. Looking at having stock injectors replaced with Bosch since the stock are a POS and will eventually fail.
Thinking electrical (short) since the noid light is weak on attempted restart
Old Jul 26, 2006 | 01:36 PM
tequilaboy's Avatar
tequilaboy
The crank fuel pulse width drops to 7.81 ms for coolant temp over 111 F.
Perhaps the small pulses are responsible for the weak light.
Maybe your just too lean to start.
Old Jul 26, 2006 | 01:43 PM
seenalot's Avatar
seenalot
One injector in each bank is bad. With the bad ones disconnected the engine restarted with no problem.
Having all 8 replaced with "Standard" mfg injectors.
GM wonders why its going bankrupt. Designes a decent product but then buys the cheapest components.
Thanks for the help, my mechanic was scratching his head.
Old Jul 26, 2006 | 10:40 PM
Sam Lam's Avatar
Sam Lam
Help us understand "one injector in each bank was bad"! What were the ohm readings on the "bad" injectors? You may also have other problems too......so be careful and do not place "all" your problems on the injectors. Just some wisdom from the school of hard knocks Also, suggest you use 22 pound replacement injectors.
Old Jul 27, 2006 | 10:13 AM
seenalot's Avatar
seenalot
Don't have the ohms reading from my mechanic. There was an unrelated problem with the ICM when it was tested.
And I was advised to stay with 22# injectors since an increase without any other upgrades would cause problems with the O2 sensor sending conflicting info to the ECM.
Old Jul 27, 2006 | 10:38 AM
RRT vette's Avatar
RRT vette
Stick with stock lb injectors unless you want to install a AFPR and have you chip tuned for larger ones. Ask me how I know.
Old Jul 27, 2006 | 12:05 PM
Sam Lam's Avatar
Sam Lam
The things you "learn the hard way" tend to be those you remember best I learned about the Multec injector issue in this manner! This forum is the best in that we all learn from each other.
To 89 won't restart, weak noid light
