Refrigerant leak stopper.
Old Jul 25, 2006 | 10:29 PM
mfi's Avatar
mfi
Default Refrigerant leak stopper.
Anyone have any experience with leak stopper in a can. I really don't want to rip out my evap coil, where I think the leak is. I went over the whole system with an electronic detector but came up with nothing. Last place is probably the evap. the leak stopper comes with a dye so it will help me find it. tried to find UV dye but could only find the whole setup which I already have, just no dye. Opinions?
Old Jul 25, 2006 | 10:34 PM
aminnich's Avatar
aminnich
Send me a PM with your address, I can send you some dye for the cost of shipping. Crap in a Can is just that, Crap. Double checked around the front seal of the compressor and the schrader valve?
Old Jul 25, 2006 | 10:46 PM
mfi's Avatar
mfi
PM sent. I take it that if I can't see a damn thing that the evap is the prob. Are they known for leaking?
Old Jul 25, 2006 | 11:29 PM
SunCr's Avatar
SunCr
Stick the Electronic Detector in the vents or remove the Blower Module or Resistor Pod from the top left side of the Evaporator Case and stick it in there - if it goes off, the Evaporator is leaking. Otherwise, frost on the windshield is a telltale sign - Refrigerant at normal atmospheres is about -32. Makes ice real quick. Otherwise, it's fairly common around here. Most discover it when max blower is less. Inlet side has a foam filter and compressor oil destroys it plugging it up. You can't see it without taking it apart.
If it checks out, take a good look at the lower half of the Condensor - hard to use your Beeper with the fan(s) cranking and the radiator and shroud in the way. You can remove the shroud and look for oil, but a dye works better in this area.
Don't forget to check for oil above the compressor on the hood which would indicate a worn out shaft seal - seems fairly common with the Nippondenso compressor. Here's a link to a guy doing the Nippo on his Porsche - case is a little different, but the seal's pretty much the same:
http://www.pelicanparts.com/techarti...so_rebuild.htm
Old Aug 2, 2006 | 10:17 PM
aminnich's Avatar
aminnich
[QUOTE=mfi]PM sent. QUOTE]
Hello, anyone home?? I sent you the dye last week and two PM's, no answer. If you want to stiff me for the postage Ok, but how about a courtesy response?
Old Aug 2, 2006 | 11:18 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
[QUOTE=aminnich]
PM sent. QUOTE]
that s**ks
Old Aug 3, 2006 | 10:36 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
He hangs out in Off Topic alot...maybe he forgot...go check OT out if ya need to.
Old Aug 3, 2006 | 07:39 PM
aminnich's Avatar
aminnich
Thanks, but I don't need to, maybe he does though.
To Refrigerant leak stopper.
