code 42
Old Jul 26, 2006 | 02:39 PM
94blue6spd's Avatar
94blue6spd
Default code 42
1994 Corvette 6spd
Have trouble starting the car. Sometimes will start up and then run fine. Other times will not start.
Code H42 came up.
What sould I replace. Please do not say opti.
Old Jul 26, 2006 | 02:43 PM
bogus's Avatar
bogus
no. that is NOT an opti code...
I think this means something is amiss with your knock sensor... it is a knocksensor code for 92/93, and I think 94 and 95... but I don't rightfully remember for sure.
You really need the Helm Factory Service Manual so as to better diagnose this problem.
Old Jul 26, 2006 | 02:50 PM
94blue6spd's Avatar
94blue6spd
I got this from http://www.corvettephotographs.com/c4vettes/ecm.htm
42 Electronic Spark Timing Circuit (EST)
42 Check wiring at ignition module. Replace ignition module. Possible ECM failure.
I already replaced both the ignition module and the ignition coil. So I do not know what else to do.
Old Jul 26, 2006 | 05:46 PM
bogus's Avatar
bogus
that link is suspect. It does not include anything to do with the opti.
Old Jul 27, 2006 | 01:53 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
With Code 42, what we have here is a failure to communicate. The ignition module and the computer are in constant communication when the engine is in operation. (over 400 RPM) with the computer telling the module the correct timing.
If communication is lost or a circuit becomes infected with false signals (bad grounds, short to battery +, Electro Magnetic Interference {spark plug wires too close to circuit wiring}, oil contamination of the circuit connectors and wiring) then the computer will turn timing control back to the ignition module and flag the code.
Possible causes:
· EST circuit open or grounded.
· Bypass circuit open or grounded.
· Reference Ground circuit open or shorted to battery +.
· A bad computer to engine circuit ground.
· A defective ignition module.
· A defective computer.
If you are testing a vehicle for this code check the routing of the spark plug wires making sure they are not to close to the EST circuit(s) wiring.
Check the connector terminals making sure they are not over-sized or oil contaminated. Check the entire wiring of the circuits for chaffing,
short(s) ground.
Alldata has a very good on-line manual system for the DIY’s that contains all the information and a trouble “tree” chart(s) for the proper method to test the ignition module and computer for your vehicle.
http://www.alldata.com/products/diy/index.html
To code 42
