rear leak!!!
Old Jul 26, 2006 | 04:52 PM
panther1's Avatar
panther1
3rd Gear
Default rear leak!!!
Yesterday, I had a new set of B&B's installed on the 92 lt1 and discovered a leak of some sort on the exhaust. The leak is occurring right where the two pipes come together. Is this my differential, if not where is it comming from?
Old Jul 26, 2006 | 04:58 PM
toolbox's Avatar
toolbox
yep it's the rear. Don't know how much trouble it is to take off and fix but I'l let you know when I get mine done.But I have a shop to use, I'm sure it will be more trouble on the garage floor
Old Jul 26, 2006 | 05:39 PM
panther1's Avatar
panther1
3rd Gear
Very much appreciated! Thanks...
Old Jul 26, 2006 | 05:55 PM
aminnich's Avatar
aminnich
Check closely. If it is the pinion seal (where the driveshaft joins to the front of the chunk) it is easy to do. Same for the fill plug. Otherwise the chunk housing bolts up with just RTV sealer and that is a larger job.
Just don't go blowing $1K or so because you let it run out of oil. And do NOT forget the posi additive, that could cause you a chunk rebuild as well.
Old Jul 26, 2006 | 06:57 PM
panther1's Avatar
panther1
3rd Gear
thanks for the advice!!!
Old Jul 26, 2006 | 08:22 PM
aminnich's Avatar
aminnich
You are welcome. Hope it is one of the minor issues.
To rear leak!!!
