124 Amp or 140 Amp?
Old Jul 26, 2006 | 07:11 PM
Dmod81's Avatar
Dmod81
Default 124 Amp or 140 Amp?
I needed a new alternator so i had a CS-130 ordered through my parts store. Turns out my car already has the CS-144 in it. I think it doesn't even have the stock L-98 alternator bracket in it anymore. In helping me out, the guy then ordered an alternator from a '92 and the
'91 ZR-1 alternator.
Hence the question... Would the 124 Amp be better, or the 140 Amp.
Dan
Old Jul 26, 2006 | 07:59 PM
vader86's Avatar
vader86
Old Jul 26, 2006 | 08:04 PM
redrose's Avatar
redrose
the cs-130 looks cooler but runs hotter, resulting in shorter life....and the cs-140 weighs a bit more...if you really want light weight and tiny, get a cs-110.
my car began life with a 130, after two failures, changed to the 140... lt1 intake mod caused a small space grab that made the 130 return...gonna use a 110 for the big block switch when snow flies.
snow.
Old Jul 28, 2006 | 06:53 PM
Dmod81's Avatar
Dmod81
Am I stupid or something, or is this alternator really that impossibe to match. Everyone that I order has a different fan and the mounting bolt that I need in the back is smaller and in a slightly different place.
Does anyone know what alternator this is? I've already ordered and looked at 4 and none matched.
Thanks.
Old Jul 28, 2006 | 08:17 PM
LD85's Avatar
LD85
I have had a 124 amp since 1997 on my 350 and now my 406, I use 2 stereo amps and still have the same alternator I bought in 97.
To 124 Amp or 140 Amp?
