Someone Please Help???????????????
Old Jul 27, 2006 | 08:37 PM
SMAR1477's Avatar
SMAR1477
Default Someone Please Help???????????????
I Am Getting A Code 1661 When I Check It. The Check Engine Light Is Coming On. As I Drive The Car It Will Go Out For A Bit Then Come Back On At Random. Yesterday It Actually Flickered Like A Bad Connection. I Was Told It Could Have Something To Do With The Pcm. What Is The Pcm And Where Is It Located At???????????????? Please Someone Has To Have An Idea???????????????
Old Jul 27, 2006 | 11:04 PM
silver86's Avatar
silver86
I'm not sure what a code 1661 is. When you first check the code, you should see one flash, pause, then two flashes; the sequence should repeat for a total of 3 "12" codes. Any trouble will flash after that initial sequence using the same format:first number, pause, second number.
Old Jul 27, 2006 | 11:07 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
They must have OBDii...code 12 test is for OBD1 cars.
try www.obdii.com
Old Jul 27, 2006 | 11:23 PM
silver86's Avatar
silver86
Ahhhh....guess I should've asked about the year first.
Old Jul 28, 2006 | 03:04 AM
SMAR1477's Avatar
SMAR1477
tes its a obd2. think i may have figured out the problem. the headlight switch seems to be the culprit. thanks for the replies though
Old Jul 28, 2006 | 07:22 AM
runner140*'s Avatar
runner140*
Fill out your profile so we know what you are driving.
Old Jul 28, 2006 | 07:34 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
And please don't post with every word starting with a cap letter. Thx.
Old Jul 28, 2006 | 07:43 AM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
Please, fill out your profile.
To Someone Please Help???????????????
