Racetronix Fuel Pump Harness.
Old Jul 28, 2006 | 04:31 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Racetronix Fuel Pump Harness.
NE one installed it with a factory pump, to get a little more performance, fuel etc.
I have a GNX fuel pump now and am probably running it on the edge, as my 396LT1 makes a good bit of power, right around 500FWHP.
Heres the harness, RX-C44-FPWHG-2
http://www.racetronix.com/RX-C44-FPWHG-2.html
Old Jul 28, 2006 | 06:42 AM
BlackC6LS3's Avatar
BlackC6LS3
I bought the kit off of a forum member but it didn't come with instructions from them. The website isn't very helpful either.
Old Jul 28, 2006 | 12:09 PM
steve40th's Avatar
steve40th
I though Racetronix has good customer service. i would email them. They are on the board here allot.
This site ahs a install instruction.
http://www.blowerworks.net/
Old Jul 28, 2006 | 09:56 PM
rodj's Avatar
rodj
Remove the fuel filler door and boot.
Disconnect the factory plug and plug in the 2 new plugs on the harness (only goes one way), mount relay under rear of car , run new earth cable (supplied ) , rum loom under car to front .
Hook fused red wired direct to Alt output terminal.
Now, what was the fuel pump feed is used to operate the new relay instead giving direct Alt power straight to the pump on a bigger gauge wire.
Less voltage drop at pump = better operation.
To Racetronix Fuel Pump Harness.
