throttle body coolant?
Old Jul 28, 2006 | 09:24 AM
Arlon's Avatar
Arlon
Default throttle body coolant?
What purpose does the coolant running through the base of the throttle body serve? Can it just be done away with? Arlon
Old Jul 28, 2006 | 09:33 AM
rodj's Avatar
rodj
Just bypass it , depending on what year model may be straight hose connector or one to adapt 2 different size hoses.
Old Jul 28, 2006 | 09:35 AM
mothersworry's Avatar
mothersworry
GM allows a small flow of coolant to flow through the throttle body, warming it for improved cold weather performance. You can remove it, however it does not free any HP
Old Jul 28, 2006 | 09:45 AM
Arlon's Avatar
Arlon
I just saw it as a potential source of leaks and it looks funny. Doubt I'll have much cold weather operating problems in Houston.. Arlon I think it will be a delete item/bypass item. Arlon
Old Jul 28, 2006 | 09:49 AM
mothersworry
I have an extra kit hanging around somewhere. If you are intrested I will send it to you for $6 shipped.
Old Jul 28, 2006 | 10:00 AM
runner140*'s Avatar
runner140*
Most of us have addressed this issue. Its easy and cheap.
Disconnect both hoses that connect to the throttle body and join them with a connector and two clamps. This is a $ 3.00 and ten minute mod. Good luck.
Old Jul 28, 2006 | 10:07 AM
tlong's Avatar
tlong
Take the hose from the radiator T and go to the tube under the passenger side fuel rail cover. No kit needed. It lowers the tb temp to cool to the touch and helps out under the hood. Every little bit helps ya know.
Old Jul 28, 2006 | 10:15 AM
rickneworleansla's Avatar
rickneworleansla
I would say go for it. You can buy the parts at a local auto or hardware store. The only dyno test I have seen on this is below.
http://www.ws6.com/mod-8.htm
Old Jul 28, 2006 | 11:30 AM
Hotred94's Avatar
Hotred94
There you go, proof that every good mod is worth it's weight in hp. I think 6 hp is pretty optimized. For a standard LT1 I would really guess the improvement is something like 2-3 hp, but doing the bypass helps clean up the engine compartment. I would do it just for that reason alone.
Old Jul 28, 2006 | 12:02 PM
95wht6spd's Avatar
95wht6spd
TBBP rocks!!!
Really I just like saying TBBP.
Old Jul 28, 2006 | 12:08 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Originally Posted by 95wht6spd
TBBP rocks!!!
i would have never guessed
To throttle body coolant?
