stupid question, oil level sensor?
Old Jul 28, 2006 | 12:27 PM
95_6spdvette's Avatar
95_6spdvette
Default stupid question, oil level sensor?
How do I remove it, is it suppose to unplug or does the bolt need loosened? trying to remove oil pan and couldnt find anything on actually removing the sensor in the archives.
Old Jul 28, 2006 | 12:39 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Are you talking about a oil pressure sensor?
Old Jul 28, 2006 | 12:42 PM
95_6spdvette
maybe, plugs in on the driver side of the oil pan
Old Jul 28, 2006 | 01:14 PM
bogus's Avatar
bogus
No, the oil level sensor. the oil pressure sensor and switch are on the back of the block, between the manifold and the firewall.
It is screwed in. Whatever you do, don't try to remove the pan with it in, cause all that will happen is the sensor will break.
put a big ole wrench on it, and loosen as usual.
Old Jul 28, 2006 | 05:16 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
It shouldn't really be that tight. I'm thinking it's something like an 1 1/8 or thereabouts. The trick can be getting the wiring plug disconnected from it first. You have to reach in a little with a small 90 degree pick or something similar and carefully pull up on the little doo-dad that locks the connector in place while gently pulling on the connector.
To stupid question, oil level sensor?
