New Rocker Arms
Would the new rockers be worth it for perfromance? I like to get more perfromance while fixing a problem while I'm at it
Since I have 103k miles on the clock (and the extra .030" of lift could use a little help) I did new Comp Cams springs shimmed to about 90lbs seat pressure (a little higher than stock) with Ti retainers, 10deg locks and discarded the oil shedders to lighten up the top (I estimate the stock shedders, retainers and locks weigh twice as much as the new setup). I did the O-ring top oil seals but kept the old Teflon bottom oil seals.
It now has 1.6:1 rockers on intake and exhaust with the stock cam and idle is maybe even smoother than before.
Initial testing saw no gain from this mod but there were knock count problems at the time. Subsequent upgrade to the ECS module eliminated the timing retard due to knock counts and trap speed improved by nearly 1 mph. My stock 700R/4 shifts at about 4,600-4,800 rpm which is a little low for my motor (see dyno pulls on my site). I believe that I will see another 1-2 mph gain when I can shift at 5,400 rpm and take advantage of the better breathing up top.
The hardest part was getting the valve covers off and and turning the crank to set the lash. The rest was mostly a matter of $$$ and learning technique.
BTW, when I had the valve covers off I cleaned, wet sanded with 220 grit and painted (wet sanding with 600 grit between coats) with very nice results. I used about 1 1/2 cans of MAD's valve cover paint (better to have a little too much). I also had to replace the two groumets (PCV & breather) as they disintegrated during removal.
