Codes 32 &34
Old Jul 30, 2006 | 10:52 AM
Canuckster2005's Avatar
Canuckster2005
6th Gear
Default Codes 32 &34
Just curious, I have 2 codes showing up, but when my SES light is on, my 86 runs not to bad, but then as soon as the SES light gos out, it won't idle, sounds like its poping through the intake, no power at all ?
Other times when I fire it up, the SES is not showing up, but then I'm back to running crappy as I mentioned above ? Any suggestions ?
Old Jul 31, 2006 | 12:58 PM
rick lambert's Avatar
rick lambert
Code 32 is most likely the EGR switch, cheap part. The code 34 is MAF related, if you're lucky it might be one of the relays, there are 2 located behind the battery, MAF burnoff and MAF power..once again, cheap parts..BUT replace both, not just one.
Old Jul 31, 2006 | 07:28 PM
headdoc's Avatar
headdoc
Acct disabled by request 16 Aug 2009
Default Code 34
Just replaced the relays and cleaned up around the MAF and code 34 went away.
To Codes 32 &34
