TPS Replacement LT4
Old Jul 30, 2006 | 12:29 PM
PacWest's Avatar
PacWest
Default TPS Replacement LT4
I just replaced the TPS on my 96 LT4. The car has 80k miles and is stock except for an airbox and cat-back.
I need to help the EBTCM learn the new TPS voltage and maybe something else because it is ideling too high. It runs better than before and otherwise seems to have cured a small high RPM miss.
How do I calibrate this new TPS? What tools do I need?
Thanks!
Ryan
Old Jul 30, 2006 | 01:43 PM
STL94LT1's Avatar
STL94LT1
Your TPS should be self calibrating. Are you sure the throttle blades were completely shut when you installed the new TPS?
Try disconnecting/reconnecting the negative battery cable and see if that helps.
Old Jul 30, 2006 | 03:38 PM
PacWest's Avatar
PacWest
I'll try the battery cable. The service manual says I must use a Tech 1 tool to help the EBCTM learn the new TPS idle voltage. I'd like to know if there is anohter tool or program / laptop setup I can use.
To TPS Replacement LT4
