knock sensor leaking
Old Jul 31, 2006 | 04:41 PM
mothersworry's Avatar
mothersworry
Default knock sensor leaking
I have the passenger knock sensor leaking. Can I back it out a little and use thread sealer on it? Can it leak through the housing? If I remember correctly it is a solid screw and should only be leaking around the threads. Any help is appreciated.
Old Jul 31, 2006 | 04:48 PM
STL94LT1's Avatar
STL94LT1
If you back it out too far, get ready for a bath. I would just tighten it about 1/2 turn, and see if that helps.
Old Jul 31, 2006 | 06:06 PM
SJW's Avatar
SJW
Thread sealants are specifically discouraged with the knock sensors. Use of sealants can interfere with the sensor's frequency or amplitude response.
The sensors come with a special treatment on the threads to seal them. If you can't get your KS to seal properly when tightened to the recommended torque (14 lb/ft, if I recall correctly, but verify that), I'd suggest you spring for a new KS, and that should solve your problem without creating any new ones.
Be well,
SJW
Old Jul 31, 2006 | 06:25 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Be well,
SJW
Folow that direction and get a new one and don't overtighten the old one USE a Torque wrench.
Thanks,Matt
To knock sensor leaking
