Need help with motor swap
Old Sep 5, 2001 | 04:24 PM
jonvolk's Avatar
jonvolk
Default Need help with motor swap
One of my friends has an 87 TPI vette. He wants me to swap in a carbuerated motor....i know its not logical but he's paying me to do it. Now for the hard part....can i use the ignition system thats in the car and how do i keep the digital dash and stuff like that? Basically i want to know what i need to do to keep the car working correctly without a TPI motor...i hope this makes sense, if you need me to clarify anything just ask and ill do my best. Thanks in advance.
Old Sep 5, 2001 | 09:07 PM
jonvolk's Avatar
jonvolk
Default Re: Need help with motor swap (jonvolk)
ANYONE????? i really need help on this one..... :(
Old Sep 5, 2001 | 09:13 PM
KYVette90's Avatar
KYVette90
Get a four barrel intake and a carburetor and put it on.
Old Sep 5, 2001 | 09:36 PM
jonvolk's Avatar
jonvolk
Default Re: Need help with motor swap (KYVette90)
the guy wants me to install a new 425hp crate motor....what wiring can i keep and what can go?
Old Sep 7, 2001 | 09:34 PM
jonvolk's Avatar
jonvolk
:mad
Old Sep 7, 2001 | 10:51 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Welcome to the forum.
No matter how much money He's paying you, It won't be enough !!!!!!
This is one of those no win projects. :crazy:
Old Sep 7, 2001 | 11:31 PM
Nomar116's Avatar
Nomar116
Default Re: Need help with motor swap (mackeyred96)
I can almost promise you you should take mackeys word for this one. I have NO experience, but I imagine if you got an L98 long block and put a four barrel and intake on, the car would function fine. There are guys on here running very similar setups. However, that said, and knowing abosolutly nothing on the subject Ill sit down and shut up, but just keep renewing the topic and your bound to get your answer.
Paul
Old Sep 8, 2001 | 09:36 AM
corvette1990's Avatar
corvette1990
You won't need to connect the harness that goes to the injectors or the air temp sensor, or the Knock sensor or the IAC sensor or the O2 sensor. You will have to use the oil temp sensor wire that is near the oil filter and the oil pressure wire that is at the drivers side rear of the intake manifold. You will need to connect the water temp wire that is on passenger side near spark plug 6 and 8. Not sure on your year, but you will also have to use the wire that sends a signal to the fans to turn on, or get one of those fan kits from corvette central or eklers. The wire from the distributor to the tach is essential too. I would also talk to one of the chip burners (fomato or ed Wright or TPIS) to find out if you need a custom chip to make the computer continue to talk to the driver info center (warning lights) and avoid a whole load of error codes flashing at driver constantly. The Transmission wires talk to miles per hour on the dash. That is as much as I know. Good Luck.
Old Sep 15, 2001 | 08:36 AM
jonvolk's Avatar
jonvolk
Default Re: Need help with motor swap (corvette1990)
Old Sep 15, 2001 | 11:50 PM
cohocarl's Avatar
cohocarl
Jonvolk,
There's a number of guys here on the forum that have swapped their tpi for a carb. (I'm thinking about doing it also) You may want to re-post your question so the header says something like "need help with tpi to carb swap" or something. I know there's a few guys here that will be happy to give you more info, but may have skipped over your posting.
My questions are if I can use the stock fuel pump, what pressure regulator to use, and what kind of clearance is left for an air cleaner. I really don't think it would be that difficult.
Thanks,
Carl :chevy
Old Sep 19, 2001 | 04:06 AM
NoWorries's Avatar
NoWorries
Default Re: Need help with motor swap (cohocarl)
Have your friend look into Pepsi can's, they are much cheaper and basically the same technology.
Old Sep 19, 2001 | 11:35 PM
NoWorries's Avatar
NoWorries
Default Re: Need help with motor swap (NoWorries)
Another good point with Pepsi can's is they already come polished, so that will save even more money.
I bet you could shove 1100 CFM through there on a naturally aspirated motor.
Old Sep 20, 2001 | 03:35 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
I doubt the distributor will work because its computer controlled and the computer needs the throttle position sensor to decide how to set the spark advance. When the throttle plates are closed, the computer uses a different table to set the spark advance.
Fuel injection is more difficult to get working but you get better mileage, throttle response and spark control.
Old Sep 20, 2001 | 03:35 PM
Craven Morehead's Avatar
Craven Morehead
6th Gear
Jonvolk,
Well, at least you received a few intelligent replies.
Old Sep 22, 2001 | 10:02 AM
jonvolk's Avatar
jonvolk
Default Re: Need help with motor swap (Craven Morehead)
I guess its hard to find good advice without being critisized for doing a favor for friend.
Old Sep 22, 2001 | 02:52 PM
GRX's Avatar
GRX
When all is said and done: Fuel injection renders you more power....but it's been said that when you design the perfect fuel injection system, you'll have a carbueretor. Good luck! :flag
Old Sep 22, 2001 | 08:08 PM
Chris@SD's Avatar
Chris@SD
Default Re: Need help with motor swap (GRX)
Depends on that cabs you go for. We sell carbs that run in the $1500+ range. That is not even the high end carb! But these carbs sit on the fastest pro stock trucks in the world!!! (PRC(Performance racing carbs) in Houston).
You will not be able to keep the computer without custom building some simulators for certain things. Put a custom dash in it and be done with it.
Good Luck. If you have alotted any less that a month with this project....
To Need help with motor swap
