caliper rattle-can it be fixed??
Old Sep 5, 2001 | 06:46 PM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default caliper rattle-can it be fixed??
i know this has been discussed before,but what did you do
to eliminate the rattling of the front calipers? I have new pins
and cir-clips in 2 yrs. ago,when i did the pads and the little clip
on the outside of the pad edge as well. Just makes the car
sound like it is coming apart.Help anyone??
Matt :cry
Old Sep 5, 2001 | 06:51 PM
Crushinator's Avatar
Crushinator
Default Re: caliper rattle-can it be fixed?? (6spd.89)
Mine does the same thing. It doesn't really bother me, in fact I don't even notice it.
Old Sep 5, 2001 | 08:03 PM
91Yellow1's Avatar
91Yellow1
Default Re: caliper rattle-can it be fixed?? (Nat96LT4)
Mine were making an awful racket so I took them apart and found the anti-rattle? clips were gone maybe yours are worn out? :cheers:
Old Sep 5, 2001 | 08:19 PM
Wildride's Avatar
Wildride
The anti rattle clips do break occasionally from metal fatigue and need to be replaced. AND they do need to be adjusted correctly so that there is tension all the time. Just bend them with needle nose pliars until there is constant tension on them between the pad and the caliper.
Old Sep 5, 2001 | 10:14 PM
6spd89's Avatar
6spd89
Thanks, i will check those clips tomorrow.I used new anti-rattle but
may be they are busted!!I will keep forum folks updated asap.
Thanks,
Matt
Old Sep 5, 2001 | 10:19 PM
jfb's Avatar
jfb
Those anti rattle clips don't last . I'd just replace them.
Old Sep 6, 2001 | 04:24 AM
93vetteguy's Avatar
93vetteguy
Default Re: caliper rattle-can it be fixed?? (jfb)
Where can I get a pair of these anti-rattle clips?
Old Sep 6, 2001 | 08:08 AM
91Yellow1's Avatar
91Yellow1
Default Re: caliper rattle-can it be fixed?? (93vetteguy)
Go to your local parts guy and ask for a hardware kit, I got mine at Carquest,they are kind of pricey for what you get.
To caliper rattle-can it be fixed??
