'84 horn relay
Old Aug 2, 2006 | 01:34 PM
84lvnlg's Avatar
84lvnlg
Default '84 horn relay
Have the books!!! and so far the horn relay is in possibly 4 places. Lots of words no pictures. Does anyone know where the '84 horn relay is located before I tear out the dash trim plates, dash pad cover and all the underdash carpet moulding. Thanks
Old Aug 2, 2006 | 02:22 PM
85vetteguy's Avatar
85vetteguy
In my 85 it was behind the DIC in the middle of the dash. Remove the bezel and I think it is behind the Heat/ac control. There is a fuse next to it. Check the fuse also. Good Luck. Guy
Old Aug 2, 2006 | 05:07 PM
Vetterin's Avatar
Vetterin
Before tearing into the dash, have you checked the metal horn cap contact on the steering wheel?
Old Aug 2, 2006 | 05:10 PM
Electricblue80's Avatar
Electricblue80
and make sure the horns are not bad and are receiving signal.
To '84 horn relay
