Gains from gears?
Old Aug 3, 2006 | 07:53 PM
Jared1984's Avatar
Jared1984
Default Gains from gears?
Hey all. I'am considering doing a set of 4.10 gears for my 93 M6. Is it really that big of a SOTP (seat of the pants) feel over my 3.45's? What kind of gains could I expect? I am pretty much stock now and It went 13.2 @ 104 with a 2.08 60' spinning) I would also get a performance tune with it as well. will that add to the feel or just fix my speedo? I will probablly have tom from Anger Management do them if anyone knows them.
Thanks alot!
Jared
Old Aug 3, 2006 | 07:56 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Yes it is a big SOTP feeling. My friends 95 went from 12.7 to 12.1 with a gear change only. He did have a Hot Cam, no headers. Went from 3.45 to 4.1. His highways fuel economy went up to, because 6th gear was actually usefull.
Old Aug 3, 2006 | 08:11 PM
STL94LT1's Avatar
STL94LT1
4.10 gears have been my favorite mod.
Old Aug 4, 2006 | 09:13 AM
Irishpilot03's Avatar
Irishpilot03
I don't think gas mileage goes up. At least it didn't for me. At 75mph my engine now turns 1800 rpm when it used to be like 1250 rpm. But you do have a useful 6th gear as Steve40th said. It is by far the cheapest, single biggest SOTP mod you can do. I did mine (including installation) for $650. I took .4 of sec off of my car in the 1/4 mile. It too is my favorite mod.
Old Aug 4, 2006 | 09:35 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Do you guys think it is a good mod for a L98 with 6 speed. I have a 3.54 now and as you say 6th isn't that usefull.
Old Aug 4, 2006 | 09:56 AM
redrose's Avatar
redrose
your car was crippled at birth by gm's "no gas guzzler tax'' edict, CAFE fleet fuel comsumption restrictions, and a mild DETUNE to control warranty costs, and more....there are definite improvements that you can make, but durability may be affected, particularly by ''tuners'' that are ready to go too close to the 'ragged'' edge (knowing that when it breaks, they won't be paying to fix it--you will)
look , learn, before you leap
Old Aug 4, 2006 | 11:13 AM
cv67's Avatar
cv67
St. Jude Donor '05
Probably get a tenth or two. 4.10-perfect gear for 6 speed.
Old Aug 4, 2006 | 12:28 PM
redcorvettedave's Avatar
redcorvettedave
Thanks alot!
Jared
I would copy Nathans Plemons set-up if I owned a early LT1 m6
you're spinning now .....and you want 4.10s? maybe just for drag racing?...what the hell I know! I would leave my rear alone for a DD!
Old Aug 4, 2006 | 12:31 PM
STL94LT1's Avatar
STL94LT1
No, too much gear for a nearly stock L98.
Old Aug 4, 2006 | 12:34 PM
STL94LT1's Avatar
STL94LT1
4.10 gears work even better in a daily driver. No loss of gas mileage, better accelleration, and 6th gear becomes useful.
Old Aug 4, 2006 | 01:12 PM
Wildcat1's Avatar
Wildcat1
His tires are the problem....or the track prep sux. I get easy 1.8s on every street tire I've owned and I have factory gearing. I know for sure I would greatly benefit at the strip with 4.10s. I'm having to drop the clutch at 4k, no slipping the clutch at all.
Old Aug 4, 2006 | 06:44 PM
bobmic93's Avatar
bobmic93
Originally Posted by Irishpilot03
I don't think gas mileage goes up. At least it didn't for me. At 75mph my engine now turns 1800 rpm when it used to be like 1250 rpm. But you do have a useful 6th gear as Steve40th said. It is by far the cheapest, single biggest SOTP mod you can do. I did mine (including installation) for $650. I took .4 of sec off of my car in the 1/4 mile. It o is my favorite mod.
Thats great! My 93 auto and 3.73 spins 2800 rpms at 75 mph. I take it thats because of the 6th gear your able to keep those rpms down?
Old Aug 4, 2006 | 07:10 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Probably the most noticeable mod you can do, and cheap too (compared to just about anything else. MAYBE 10% less mpg at 80mph. But the downside is you probably are going to develop traction "issues".
Old Aug 4, 2006 | 10:08 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I'm running the 3.45s with the ZF and find the 6th gear to be fine on the highway and excellent mpg, although I usually drive 80+ mph.
Look at your trap speed, and figure out what RPM you're comfortable with there. You don't want to have to shift into 5th gear at the strip.
Old Aug 5, 2006 | 08:24 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Thanks alot!
Jared
Tommy is a good buddy of ine.
Old Aug 5, 2006 | 11:00 AM
Irishpilot03
bobmic93, you are correct, the six speed is keeping the rpms within reason. Jared1984, traction is always going to be an issue, but that is workable. I consistently run 1.6 60' times on street tires, but I have to do an idle to 1500rpm launch because otherwise I'll go up in smoke. With a stock motor to mildly modded motor, you should be going through the traps in 4th. After my last mod, it pushed me into having to shift into 5th. Currently, I am going through the traps at 111mph, so that would give you an idea on when you will have to shift.
Old Aug 5, 2006 | 03:24 PM
thirdtimevetteowner's Avatar
thirdtimevetteowner
What's a good gear for an L98 auto? I got a spakin new D44 w/3.54's ready to install. Can't wait to get to the track and finally be able to spin my BFG drag radials, which I couldn't do w/the pathetic 2.59's it came with. I intend to short shift into second because of the HUGE difference in the 1st and 2nd gears in the 700R4. Then cranking it up close to 5k going into 3rd. Anyone have this setup? The only mods right now are frisbee removal, lower thermostat, Dewitt rad. Soon to come are either Hookers or TPiS w/ true duals from Random Tech. Muffler choice is still up for grabs, so to speak. Am thinking of Flowmaster Delta 40's w/ZR1 tips welded on, but don't know if they will be a direct bolt-on (keeping the same hangers that is). Anyone running a similar system?
Rich K
P.S. I hate the Flowmaster Delta 50's because of the longish, skinny tips, so I will need to use an offset 2 1/2" inlet/dual outlets. I read a post by someone on here that did this type of mod, but can't find it to inquire which mufflers he used. Any help appreciated.
To Gains from gears?
Old Aug 5, 2006 | 09:13 PM
bobmic93's Avatar
bobmic93
Actually Im going through the traps in 3rd at 114 mph (my best) but my rpms are at 6000 at that point and my hp curve pulls to 6300.
Old Aug 7, 2006 | 09:28 AM
Wildcat1's Avatar
Wildcat1
Irishpilot, you have the same mods as me listed in your sig, but I don't have gears. I also run through the traps at 111ish. What are your quarter mile times with the gears?
Old Aug 7, 2006 | 09:51 AM
mseven's Avatar
mseven
I don't think that's the answer, the point would be to keep the RPM drop less between 1-2.
