It is the tranny, probably from the cooling lines. Not much is on the ground but it is red and smells burnt.
Thanks for the help though, and unfortunately is not something easy to fix at work. So off to the tow truck thank god for AAA Plus.
This morning on the way into work right before I pulled into the lot there was white smoke pouring out of my hood, so I rushed into a spot and popped the hood. By the time I parked the smoke was gone but it looks like the wire to the coolant sensor in the passenger side head is missing.
My questions are is the sensor for the gauge or the computer, and if I attempt to drive home will this cause any over heating problems? It will be low 90's in Philly and I don't want to get stranded in shore traffic tonight on the way home.
It seems to me like the fan was on even thought the temp said it was 216 after sitting at the traffic light, which is something I would expect and also since the gauge is working that leads me to believe the sensor is for the computer.
Sorry for the long post and any help would be appreciated.
Thanks,
Bob
The sensor in the passenger side head is a redundant fan switch in the event the main temp sensor fails (which on our 85 is in the front of the intake manifold)or ecu fails. It will activate the cooling fans when temps exceed its preset limit to continue cooling the car. I dont know if you'll get a code if it is not connected. As long as your ecu and main coolant sensor are working properly I dont think you'll have a problem.
I have no codes showing which seemed odd to me since I thought it was for the computer.
But if it is a redundant fan switch then I don't see any issues since the fan seems to work, also no aux fan for me. At my luch break I will be able to investigate further.
The switch is redundant IF you have no auxiliary fan. If you have an auxiliary fan, that is your auxiliary fan switch, and the only means of activating it. As super cautious person, before you leave work, turn the ignition to "On" and ground the wire to the switch. That will cause whatever fan it controls, to run. Again, as a super precaution, especially if it only ran the main fan (no auxiliary fan on the car), ground that wire before you head for home. That will cause whichever fan to run constantly, normally not a great idea but that is safer than not coming on at all. Also, before you leave for home, check and top off your cooling system. That white smoke had to be exhausting coolant.
I replaced all of the cooling hoses last year, and I did notice that the connector was loose for the switch when I replaced the pass. exhaust manifold a few months ago. Since the wire is now missing and it smelled like burnt wire insulation I would think that was the cause of the smoke.
Also I have no aux fan, just the main one. So if that is the case it should operate normal, but I wanted to ground it can I use the ALDL plug with a paper clip? If so what pins?
I wouldn't expect such a low current wire to cause "white smoke pouring out of my hood". It won't cost anything but a moment of time to pop the radiator cap, once it's cool, to check and top off the coolant.
I didn't catch your comment about the aux fan, in your last post until after I replied. Since that switch IS redundant on a car, such as yours, with no auxiliary fan, there is no need to mess with it, to get home. If you were to do anything, it would be to ground the wire that connects to the switch. Stay away from the ALDL. You don't want to drive home in the field service mode.
