Installed a AFPR and no change.
Old Aug 5, 2006 | 11:27 AM
RRT vette's Avatar
RRT vette
Default Installed a AFPR and no change.
I got around to installing a Holley AFPR and no change. My 86E has been running rich ever since I got it running again. The injector that were in it were bad so I installed 24 lb Accel injectors. Still running rich and have done tons of troubleshooting to find the problem. I have (over the last 4-5 months) narrowed it down to either too much fuel pressure (stock FPR at 40 psi vac on/46 psi vac off) or needing my chip tuned for the injectors. Well after yesterday looks like the chip is next. I got the fuel pressure down to 34 psi vac on/40 psi vac off and it runs and smells the same as before. I hate to lower the pressure anymore and am really unable to because the adjustment dial is touching the plenum. I guess I will be sending my chip for some tuning.
I was able to run the TunerPro RT for a few minutes but it keep losing the ALDL connection, so really haven't had time to try again.
Any suggestions or comments welcome.
Old Aug 5, 2006 | 12:46 PM
Aardwolf's Avatar
Aardwolf
Mine has been rich to. I have a ticking sound that I thought was the injectors, it isn't, I unplugged each injector and the ticking did not stop. Must be a lifter or rocker. Does yours tick at all? When you reset the IAC and set min. idle speed, can you set it down to 550 RPM? Mine wouldn't go lower then 1200. Extra fuel from the ticking, or vacuum leak. Does yours have any extra symptoms? Mine runs like a champ but has a slight lope to the idle.
Old Aug 5, 2006 | 01:01 PM
RRT vette's Avatar
RRT vette
My 86E is mostly stock except for the exhaust system. My injectors make a ticking sound but not audible until you get real close to them. I can put my finger on them and fell the ticking. Sounds like a lifter in your case. When you extend the IAC when setting minimal idle this lets the throttle plates control idle. My RPM guage doesn't work so I just listen to the engine. I can get it down to where it almost dies, but stays runnning, before I connect the IAC, ect. I'm not sure what RPM it's at, but I will say around 450-500. If you can't get the idle down with the IAC extended and disconnected and if the TPS is at the correct postition I would say vac leak. At idle mine has what sounds like a lope and the car shakes a bit. I have no symptoms except for the shake, rich smelling exhaust (black plugs), and a hesitation when I quickly hit the accelerator at idle.
Old Aug 5, 2006 | 01:16 PM
rick lambert's Avatar
rick lambert
Been awhile, kinda wondered how it was going.A couple things, did you ever check your distributor? I have to admit, I can't remember about your exhaust..headers? If I remember correctly your BLMs were in line weren't they?
Old Aug 5, 2006 | 01:27 PM
Aardwolf's Avatar
Aardwolf
Hmm it's sure gonna be good when these are fixed!
Old Aug 5, 2006 | 01:35 PM
RRT vette's Avatar
RRT vette
Yeah Rick, I was able to take out about 7 hours yesterday to work on this basket case. I have a different thread on the distrubitor issue. I still have the stock exhaust manifolds, no precats, hollowed cat (so the previous owner tells me), and Dynomax mufflers. My BLM's from the last scan where 108. I was short on time at dark last night and unable to keep the ALDL connection on TunerPro RT, so I just let it be for now. Did you see what fuel pressure I am at now 34 psi and still runs the same..
Aardwolf, I'm ready to drive this thing and I know you have been have your problem for some time now too.
Old Aug 5, 2006 | 03:11 PM
rick lambert
New injectors, new AFPR and you're still running rich....time to go back to the 02 circuit. And I know that some places (shops) are addiment about which brand of 02 sensors they will and will not use. This may just be a case of a **** poor 02 sensor.
Old Aug 5, 2006 | 03:30 PM
RRT vette's Avatar
RRT vette
Well, on the scan yesterday, for the few minutes it worked, my O2 sensor stayed around .75-.85v. I had installed a heated O2 sensor back years ago and changed it to I believe a Bosch one wire sensor just a few months ago and same results as far as exhaust smell go. Still no codes and no vac leaks. Although I forgot to connect the brake booster vac back up yesterday and noticed right off the bat.. a loud hissing sound, but corrected it. When I set the timing, disconnected the EST and set at 8* BTDC (this time..seemed to idle better at 8*) and shut off and reconnected at the scan showed at 22* at idle. Looks good and the engine sounds like a sewing machine when running at idle.
Old Aug 5, 2006 | 03:52 PM
mseven's Avatar
mseven
Yep, that would be the first place I would look. You need to see if it is "bouncing"around or just staying at 900mv. or whatever # above 450 or so.
I didn't look at your combo but IMO if you start heading down to low in FP you will sacrifice the spray pattern/atomization of the injector, not to mention you will start noticing other things on the scan. I would be looking to get it right at around 44-45psi. w/vac. removed. Also all changes should be done in small increments so you can see the effect.
You might want to go into the control panel on your lap top and make sure you are getting the comm port you want. TP rt will automatically find the hardware when you get it right. MO
Old Aug 5, 2006 | 04:17 PM
RRT vette's Avatar
RRT vette
On the scan the O2 sensor numbers stay between.75-.85v and they do bounce around but stay on the rich side. I have a stock engine/chip with exhaust mods and 24 lb injectors. I will have to go back communication port...sometimes it stays connected and sometimes it comes and goes.
Old Aug 5, 2006 | 04:40 PM
mseven's Avatar
mseven
IF it is only staying between .750 and .850mv. that would indicate an issue. It should be bouncing rapidly between 100-800mv.(aprroximately depending on whats done etc.) and not staying in one area.
Old Aug 5, 2006 | 04:50 PM
RRT vette's Avatar
RRT vette
Well, those are the numbers I see more frequently. It does bounce all around, but I never see .55v or lower even at idle. Yesterday, My coolant temp was over 200* so in closed loop those numbers in the last post where what I saw for the minute or two I scanned. Field Service Mode shows two blinks a second most of the time (after closed loop)and one blink a second when just cruising at 55 mph.
Old Aug 5, 2006 | 06:24 PM
rick lambert
I'll hook up the scanner in the morning and get back..but, to me it's very hard to just look at the 02 on the scanner and say good or bad, simply because it does jump around so much.That's why it's important to look at BLMs (long term fuel trim). We should also say..you've changed the ECM. Basically you've almost replaced everything that would contribute to a rich condition. I know you changed the 02, but I also know some shops refuse to use some brands because they say the calibrations are off..don't know about Bosch, they've always been a good company. I just have to believe with new injectors,new AFPR, different ECM...that it has to come back to the 02 or 02 circuit.
At work now, then a party tonight.
Old Aug 5, 2006 | 07:05 PM
mseven's Avatar
mseven
I'll hook up the scanner in the morning and get back..but, to me it's very hard to just look at the 02 on the scanner and say good or bad, simply because it does jump around so much.That's why it's important to look at BLMs (long term fuel trim). .
Agreed, and in his post stating it "sitting" at 750-800mv, one could only extrapulate from there. When mine froze up at at.900mv it put the BL pinned at 108, and then threw the code.
Old Aug 5, 2006 | 07:19 PM
rick lambert
And I think that's exactly where his BLMs are...108, if I'm not mistaken.
Old Aug 5, 2006 | 09:05 PM
RRT vette's Avatar
RRT vette
Yeah, the new injectors in Feb. (ran the same with unknown lb injectors previously), a different 88 ECM 2 months ago, and a AFPR as of yesterday. I don't think the O2 sensor is faulty or wiring is bad/grounded (no O2 sensor codes at all/ever with either ECM). It's done the same with 2 different ECM's, one being a unknown burnt chip. I notice the o2 sensor reading going all over the place but staying on the rich side of the ECM readings. Never have I witnessed it below .45v and the exhaust will burn you eyes and soak your cloths it's so rich. I have uses two different O2 sensors in the last few months and one being a heated sensor and same thing, except I didn't run a scan with the heated sensor in. The one in it is about 3 months old but not alway full proof being new..you know how it goes. I contacted Alvin (supporting tuner) and he tells me that when you increase injector size you will need to progam the chip for the increase and a AFPR is just a band-aid solution. I'm really stuck on this one and the tune sounds like the next step. Been working on it so long it's becoming a bad habit...at least the wife thinks so.
Thanks guys.
To Installed a AFPR and no change.
