Security System Disfunctional :[
Old Aug 6, 2006 | 09:41 AM
Monkeynutz's Avatar
Monkeynutz
Default Security System Disfunctional :[
Alright well let's see...
I removed the fuse for my security system because the beeping when you have your doors open and the keys in was going on forever nonstop.
I don't know why this is, I have no idea what to do!
Anyone had this problem?
Old Aug 7, 2006 | 05:53 PM
bsmutz's Avatar
bsmutz
Alright, I'll tackle this one. Let's see, the factory wanted to warn you when you were leaving your keys in the ignition and opening the door so that you wouldn't lock them in the car. They didn't realize that you might want to leave the doors open with the key in the ignition. If you were lucky, like me, this system would only work intermittently and the beep would turn into more of caricature of a beep. Since you obviously aren't lucky, you have five choices. Live with it the way it came from the factory, disable it completely so it never works, cut the wires and bypass the beeper so the rest of the system works, only disable it when you are planning on leaving your doors open and the keys in the ignition, or sell the damn thing and be done with it.
