Quick AC/Heater blower question
Old Aug 6, 2006 | 11:50 AM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Default Quick AC/Heater blower question
I still can`t find my FSM, its hiding around here somewhere. On my `87- manual AC, blower motor, does anyone know what the part is called that is mounted with 2 screws on the left side of the blower motor, & also what the GM part# might be?. Mine has a sticker on it that reads HKR882401, but that does not seem to be a part number, according to the " techs " at AZone. They even said that they cannot order the high speed blower motor resistor for these cars anymore.
Old Aug 6, 2006 | 11:55 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
If it's on the blower housing, leeeft side facing out, it is the spark control module. Works with the anti- knock sensor. The blower control resisters are on the top right of the blower housing.
Old Aug 6, 2006 | 12:01 PM
kenv's Avatar
kenv
St. Jude Donor '10
Thanks! I`ll put that baby back where I found it. I had no low fan, just high. Now no fan at all. The motor work fine if I jump it to direct 12v
Old Aug 8, 2006 | 05:43 PM
kenv's Avatar
kenv
St. Jude Donor '10
UPDATE: the fan relay was clicking when I turned the switch, but I had no blower. I replaced the relay with a new one from NAPA, & sonofagun , diden`t the sucker start working perfectly. Only $11.00- thats the cheapest fix so far
To Quick AC/Heater blower question
