l-98 With mods. How much cam?
Old Sep 6, 2001 | 03:27 PM
Ed Dudwoie's Avatar
Ed Dudwoie
Default l-98 With mods. How much cam?
Any suggestions for cams for a 91 L-98 Car is street driven with the following mods. Cold air intake, 58 mm throttle body, Large tube runners, Hookers long tube super comps with side exhauset, B&M shift improver, 3:73 gears, underdrive pulley.. Don't mind a slight lope. Engine runs out of HP at about 4500 rpm on dyno. Thanks for any input, Duddy
Old Sep 6, 2001 | 03:37 PM
scorp508's Avatar
scorp508
Default Re: l-98 With mods. How much cam? (Ed Dudwoie)
You will probably get two different camps supporting either the TPiS ZZ9 camshaft, or the Lingenfelter 74219 camshaft.
Lingenfelter 74219
Dur @.050":219/219
Lift w/ 1.5:.525"/.525"
Lift w/ 1.6:.560"/.560"
C/L:112
TPiS ZZ-9
Dur @.050":212/226
Gross lift:.483"/.520" (I assume this is with 1.5)
C/L:112
Old Sep 6, 2001 | 04:35 PM
1MoorTym's Avatar
1MoorTym
I just installed the GM ZZ4 Cam. Almost identical specs as the TPIS ZZ9 Cam and about half the price.
Used that cam with the entire ZZ4 valve train and an Accel base. Car is stronger than ever, didn't lose any low end it runs perfectly with the stock chip.
Old Sep 6, 2001 | 05:23 PM
ralph's Avatar
ralph
Default Re: l-98 With mods. How much cam? (scorp508)
these are two good choices. add to that the LPE 211 which is very similar to the zz9. however none of these cams is going to stop your HP from falling off where it does. that is a function of the long runner intake.
Old Sep 6, 2001 | 05:35 PM
Bill Reid's Avatar
Bill Reid
Default Re: l-98 With mods. How much cam? (ralph)
Ed,
Also, be careful with the rest of the drivetrain when selecting a cam .500 or higher.
Old Sep 6, 2001 | 05:38 PM
-=Jeff=-'s Avatar
-=Jeff=-
TPiS ZZ-9
Dur @.050":212/226
C/L:112
Scorp, You have assumed correctly
Old Sep 6, 2001 | 08:28 PM
Aaron's 87's Avatar
Aaron's 87
You can get more than 4500 out of a well ported head, intake and LTR setup with good exhaust. Your heads will limit you, but the stock cam is a torquer. You will need programming for a MAP car with a cam. Be careful about overcamming it. You may want to consider a new torque converter with the cam swap.
Old Sep 7, 2001 | 03:07 AM
Yguy's Avatar
Yguy
Default Re: l-98 With mods. How much cam? (billreid1@home.com)
Re: l-98 With mods. How much cam? (ralph) 3:35 PM 9/6/2001
Ed,
billreid,
Don't you mean VALVETRAIN? Not intended as
criticism, only for clarification.
Bob. :cool:
To l-98 With mods. How much cam?
