high idle problem
Old Aug 8, 2006 | 12:14 AM
canon1414's Avatar
canon1414
Default high idle problem
Hey guys, my 90 has a really high idle problem it sometimes idles between 1500 to about 2200. Im going to test the tps tomorow with a voltmeter what else should I test.
thanks Mike
Old Aug 8, 2006 | 08:12 AM
jimmers's Avatar
jimmers
You can check the timing, tps, IAC and for vacuum leaks.
Old Aug 8, 2006 | 08:27 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
When's the last time you cleaned your throttle body, too? Check the TechTips section of this Forum. There's a really good article on how to do this and reset your base idle at the same time.
Once you've eliminated vacuum leaks, a good TB cleaning really mellows out your base idle, improves throttle response and picks up fuel economy a tad, too.
Old Aug 8, 2006 | 10:28 AM
RRT vette's Avatar
RRT vette
I agree with the fellows above. I would go ahead and clean the TB and IAC and follow the steps HERE to set base idle. Now remember the desired idle is burned into the ECM. It would be good to also check/reset timing to 6* BTDC with EST disconnected.
Old Aug 8, 2006 | 11:12 AM
george4's Avatar
george4
With a little wear on the body, the stock spring does not always bring the throttle cable all the way down to idle. If that is your problem, a cheap fix is to add another spring to bring it down. I got a generic coil spring from an auto parts store and bent the ends to fit between the bracket and end of cable.
To high idle problem
