Will this Smog delete fit?
Old Aug 8, 2006 | 04:38 PM
C4CBF's Avatar
C4CBF
Default Will this Smog delete fit?
Says it is for a 88-92, can't imagine it would have changed much from my 86. Although as my wife would say I have been known to be wrong on some occasions... Thx for the help, Chris
http://cgi.ebay.com/ebaymotors/88-92...6826QQtcZphoto
Old Aug 8, 2006 | 04:49 PM
bogus's Avatar
bogus
I am betting not. That's for an f-body... they can be different.
Old Aug 8, 2006 | 05:48 PM
C4CBF's Avatar
C4CBF
True, but doesn't the smog stuff line up all the same if it is a TPI?
Old Aug 8, 2006 | 06:07 PM
Steel Blue 91's Avatar
Steel Blue 91
I'm thinking not. That piece dosen't look like it has a place to bolt the alternator. Besides, in 92 the Corvette went to the LT1 and (if I'm not mistaken) the AIR pump became electric and moved to the headlight well so the years it will fit don't match the vettes. Just my $.02
Old Aug 8, 2006 | 06:18 PM
86VX1's Avatar
86VX1
i don't think it will, where would you attach the alternator to air pump bracket?
Old Aug 8, 2006 | 06:29 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
F body=long water pump...Corvette=short water pump Won't work, and if it did a waste of time.
Old Aug 8, 2006 | 06:39 PM
87vette's Avatar
87vette
No they don't.
Old Aug 8, 2006 | 11:59 PM
Steel Breeze's Avatar
Steel Breeze
Ain't gonna work dude, Unless you are a fabricator, then you can make it work...
Old Aug 9, 2006 | 12:16 AM
goldeneye_vet's Avatar
goldeneye_vet
Here is what you need.
http://cgi.ebay.com/ebaymotors/85-91...QQcmdZViewItem
I have seen them on ebay new as well. Might have to dig a little deeper.
Old Aug 9, 2006 | 02:36 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
This above ,Mid America has if I remember, smog pump delete and I have one on my 86.
The other you have in your thread is the A/C delete and is cheaper through GM parts direct.
I know that should not fit your car.
Old Aug 9, 2006 | 04:11 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Accessory locations are different, don't bother.
Old Aug 9, 2006 | 12:01 PM
C4CBF's Avatar
C4CBF
Do you the part#'s for the AC and AIR delete pulleys on GM Parts Direct? I had a little trouble finding it in the site. Thx
Old Aug 10, 2006 | 02:52 AM
REDC4CORVETTE
One hour down and I think I found it.
http://www.gmpartsdirect.com/results...umber=10055890
Old Aug 10, 2006 | 09:21 AM
C4CBF's Avatar
C4CBF
Thanks a lot for finding that for me!
To Will this Smog delete fit?
