clearing derm codes
Old Aug 10, 2006 | 06:32 PM
Hooked on Vettes's Avatar
Hooked on Vettes
You can use a jumper wire with a momentary switch or just use a jumper wire.
Jump pin A to K.
Turn the ignition to run.
When the INFL REST begins to flash the codes
Remove the jumper from Pin K for 3 seconds +- 1/2 second.
Reconnect A to K for 3 seconds +- 1/2 second.
Remove jumper wait 10 seconds then turn ignition off.
You may have to try this acouple of times. The 3 second time frame must be accurate.
Looking at an analog clock with a second hand makes it easier.
[F|E|E|C|B|A]
[G|H|J|K|L|M]
