How many times do you flush?
Old Aug 10, 2006 | 06:17 PM
ALLT4's Avatar
ALLT4
Default How many times do you flush?
Your oil; after major motor work or any motor work for that matter if you're **** like me.
When I finished my head cam work I filled it up with some regular 5-30 oil because it would just be changed quickly anyway. Gets rid of the assembly lube and any other crap that might have gotten into the oil pan or any other contaminants that might have found their way into the life blood.
Shortly after I decided everything was cool, about 100 to 200 miles I changed back to Mobile 1 Synthetic 5-30
I wonder if I should do it again, the oil I used at the initial start up was still clean when it came out. So now with the regular synthetic back in it should be as clean as it's going to get right?
Old Aug 10, 2006 | 06:27 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Right after i do my business, then before i get up... oh .... you mean the vette, heck,
run dino after engine work, then back to synth,, mobile1
Old Aug 10, 2006 | 06:53 PM
paulies85's Avatar
paulies85
When I had my motor work done, 200 mi. with dino, drain, 1000mi. with dino, drain, fill up with mobil-1
Old Aug 10, 2006 | 10:48 PM
TheCorvetteKid's Avatar
TheCorvetteKid
I flush the engine every oil change, believe it or not.
The way I look at it:
1. Engine flush is relatively inexpensive
2. I'm changing the oil anyway
3. Easy procedure to follow:
Pour the bottle of engine flush into the engine
Start engine and let run for 15 minutes (under no load!)
Turn off engine, and drain used oil.
Fill crankcase with your favourite motor oil.
Old Aug 11, 2006 | 11:31 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I've found that since the synthetic's oil been used in the engine since day one, it stays remarkably clean by nature. That M-1 packs a heckuva detergent package!
Old Aug 11, 2006 | 03:30 PM
bowtie350_428's Avatar
bowtie350_428
If its yellow, let it mellow;
If its brown, flush it down.
Sorry man, I just could not resist… At least it’ll gave you post a bump.
Old Aug 11, 2006 | 04:27 PM
87vette's Avatar
87vette
Old Aug 11, 2006 | 04:35 PM
ALLT4's Avatar
ALLT4
Well I titled it that way thinking it would get a few more looks. Guess it didn't work.
To How many times do you flush?
