That didn't seem right when I just started the car about an hour after I let it sit in the rain. I checked the CTS, unplugged it and plugged it back and it still says 299 degrees. Where does the digidash get its coolant temp input from??
The guage gets its information from the sensor on the driver side head between cyl #1 & 3 If it's the 89 in your info. The computer gets it's from the front of the intake manifold.
Well, it doesn't look like the insulation is broken. Could some wire in the harness be shorting itself to ground? What about an open in the circuit? How do I go about checking the wire up in there? Could the rain water be shorting something out?
I just hate seeing that 299 degrees for the coolant temp because I really would have no idea what the coolant temp really is.
Oh same problem here, actually thats fake temp b/c cTS is either loose or no contact with wire, finally changed that CTS between #1 and #3 cyl in head. CTS is not cheap 40 bucks. Problem soved after CTS replacement.
Are you saying that its probably just a bad sensor? I'd like to try and ohm it before replacing it. Some wiring could have gone as well. Could there also be a fault somewhere in the digidash?
I have a feeling that a short would cause it to read 299 and an open in the circuit would cause it to say Lo. Correct me if I'm wrong...
Does anyone have an ohm chart for this sensor?
Well, car still runs fine with a "299 degree" reading right on the digidash, so I can't be overheating.
I think this is strictly only for the digidash input.
I hope its just the sensor thats bad and not wiring. Tracing shorts in the harness is a nightmare.
yep as i told u its a fake temp only for dash, i drove whole week with 299 temp displaying on my dash, i drove 80 miles back n forth to work, not a problem here and than finally trying to wire it, i broke the blade connector projected from CTS so i have no choice but to replace it,
Make sure u emptied radiator or atleast suck a gallon or 2 or fill radiator and bleed, burp radiator after putting back new sensor. Expect lot of coolant from that CTS location once u removed it, use anti sieze on thread's of CTS. Goodluck.
Here is the acid test. With the engine off, turn the ignition key to "On". Observe the gauge. Remove the wire from the sensor and recheck the gauge. Now, ground that wire. Check the gauge again. If the gauge reads 299 one way and "Low" the other, between being disconnected and grounded, then the sensor is bad. The Ohm readings for the sensor at different temps is in your FSM. If, when you ground the wire, the auxiliary fan starts running, you have proved the wiring for the aux fan, the relay, the fan motor, and me as working and being correct as to the locations of the sensors. If so, move from the fan switch to the other side of the car and perform the same checks on the REAL gauge sending unit in the right head between the #6 and #8 spark plugs.
One of the reasons you're getting different solutions to your problem is because you never stated what year Vette you have. From your profile you have an 89 but there are people who own more than one Vette.
On your 89 the sender for the Gage is between spark plug 6 and 8. It has a single spade lug with a Dark Green wire.
Here's the resistance values and what the gage should show.
1.6K ohms or higher should read LO
1.06K ohms=110F +-6F
254 ohms=180F +- 6F
135 ohms=220F +-6F
75 ohms=261F +-6F
Unplug the Dark Green wire from the sender. Turn the ignition on. Coolant display shoud read LO. If it does the wire and gage are probably good and the sender is bad.
If the display still shows 299 the wire is shorted or the Gage/Dash cluster is bad. With the Dark Green wire unplugged, use an ohm meter and measure the resistance of the sender from the spade lug to ground.
