I've got to get to the wire harness behind the dash cluster ,Is there a easy way to get there or will I have to take the intire dash apart?
Thanks for any help,
Randall:
Randall:
Thanks,but it looks like I have ecm,or cluster problems. Last night the cluster went crazy,started blinking overlayed readouts ,car starts,runs good,but digital read is goofy.I have had a problem reading the codes,I took it to a friend that had a scanner and it would not show anything,scanner readout was blank,two scanners,same thing.When we pluged the scanners in a fan would start runing but no readout.
Any Thoughts?
Thanks Again
Randall
What kind of scanner? I knwo the Ease Diagnostic tool, if an older one, caused the LCD to go blank.. can you post a picture of what the display is doing?
One was a snap on and don't remember the other.I can't get the codes to read with the jumper either.I haven't figured out how to send pics yet,but I'm working on it.
Thanks,
Randall
It just looked overlayed because it was blinking so fast.
Just blinking,any thougts?
Randall
